MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    Have you tried refining your SMC3 setting, in particular Max Limits:
  2. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    yes but the motor didnt get to the max limit the motor not stopping from smc3 the smc3 crash when there is big movming
  3. absyfadhel1
    bahrain
    556Coins
    i saw this and i thought its maybe like my problem, i think that my arduino get overloded so its crash.
    does this faq help in any h-bridge driver, or only for sabertooh
    https://www.xsimulator.net/community/faq/baud-rate-arduino-and-sabertooth.339/
    when i change 115200 baud instead of 500000 in simtools there is no motion , so do i need to ground pin 8 and reset as said in faq?... aif so so all i need to put wire from pin 8 to the motion body or somthig els?
  4. absyfadhel1
    bahrain
    556Coins
    i tried make it 91600 and 115200 but no motion, only if it on 500000 its work but stiop the motion when fast move
    153,770Coins
    +11,149 / 57 / -2
    My guess it is an issue with SMC3 configuration, your hardware, or some combination of both.
  6. absyfadhel1
    bahrain
    556Coins
    This is my setting
  7. absyfadhel1
    bahrain
    556Coins
    when motor on green line look like what is show now, but when motor of is straight , nothing touching body i check all wire and connection everything good
    153,770Coins
    +11,149 / 57 / -2
    Max limits is very low.
  9. absyfadhel1
    bahrain
    556Coins
    yes i make it very low to be sure that motor not turning off because of pot , but its turn off without show in smc3, all i have to do when turn off remove usb cable and reconnect it
  10. absyfadhel1
    bahrain
    556Coins
    153,770Coins
    +11,149 / 57 / -2
    As per previous post, this is the function of Max Limits, which will disconnect if exceeded, as a safety mechanism:
  12. absyfadhel1
    bahrain
    556Coins
    oh yes bro its for more safety , but my motor didnt across the max limit the motor turn off when i move the motor fast
  13. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    Moving a motor fast tends to be associated with overshoots.
    153,770Coins
    +11,149 / 57 / -2
  15. absyfadhel1
    bahrain
    556Coins
    so what i need to do in this situation ?
  16. absyfadhel1
    bahrain
    556Coins
    do i need just to increase kd?
    153,770Coins
    +11,149 / 57 / -2
  18. absyfadhel1
    bahrain
    556Coins
  19. absyfadhel1
    bahrain
    556Coins
    153,770Coins
    +11,149 / 57 / -2
