Showroom Motion platform "Catopult"
Discussion in 'DIY Motion Simulator Projects' started by kalbasator, Jul 1, 2022.
  1. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hi all!
    I would like to introduce myself, my name is Victor. Was boring and I decided to design and build a mobile platform for myself. At the moment, I have built an almost completed frame of the platform. Temporarily used an office chair for fitting and general understanding.
    Below is some description and photos.
    Components:
    SMC3utils
    SimTools
    Arduino UNO *2pcs
    Hall sensors *4pcs
    Motor drivers (X bridges)
    Used 4 motors 300W 24V with gears 50:1 300W.
    Power supply 24V 2500W. mains supply 220V
  2. kalbasator
    Kazahstan, Almaty
    170Coins
  3. kalbasator
    Kazahstan, Almaty
    170Coins
    I assembled all the components of the platform the other day, I decided to check whether everything moves without distortions, etc. And on the front levers I noticed that they touch the reactive levers.
    Eh, I'll have to make the levers wider.
    I plan to mount the Hall sensors directly on the gearbox shaft, but have not yet decided how, I think through helical gears or through a belt drive.
    Or maybe restrict the lever movement programmatically?
      104.8 KB
      413
      121.5 KB
      394
      122.5 KB
      440
  4. kalbasator
    Kazahstan, Almaty
    170Coins
    Приступил к подключению электрических компонентов. Надеюсь, скоро будет первый запуск.:)
  5. kalbasator
    Kazahstan, Almaty
    170Coins
    Hall sensors, power supply installed. It remains to connect all this and you can make the first start.
    I also received a DIY License SimTools v2 Edition. As soon as I launch everything, I will purchase the Pro version.
      89.7 KB
      368
      137.5 KB
      345
  6. kerya5
    kerya5 and instead of the heart a fiery motor
    Voronezh
    Russia
    - 1,187Coins
    2DOF, Arduino, Motion platform, 4DOF
    I'm very interested in your 100 amp H-bridges, how did they perform?
  7. kalbasator
    Kazahstan, Almaty
    170Coins
    [QUOTE="I'm very interested in your 100 amp H-bridges, how did they perform?[/QUOTE]
    I haven’t run them yet, I just made a couple of inclusions and that’s it. But I heard from one participant that they are good, he is now assembling 6Dof with the same drivers
  8. kalbasator
    Kazahstan, Almaty
    170Coins
    Hi all!
    Does anyone use a usb hub when connecting two arduino to a computer? Which hubs are better to use - with separate power supply or directly from the motherboard?
    How then does Windows see the hub in the device manager? Are there any problems in assigning interfaces to Sim Tools?
  9. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    hello there. I use a usb hub (a 7 slot sub hub with no additional power) to connect all my arduino, etc. 1 for the motion, 1 for ambient light, stm32 for DIY wheel, and usb soundcard for DIY bass shaker.
    from my experience there is no problem, but to mitigate the risk from cut off connection, it's better to find a hub with separate power.
    in device manager, it's just as another port, just add more numbers. you can plug and unplug the usb of arduino that has simtools, to know which one is the right port
  10. Gadget999
    12,132Coins
    I tried using diodes to protect the power supply, they got very hot !
    Just use the power supply to charge the battery
    Then take the wires from the powersupply to your motor driver
  11. kalbasator
    Kazahstan, Almaty
    170Coins
    Following the diagram, I drew connections, added another capacitor, but I'm not sure which is right.
    If I supply + and - to the diode bridge from the power supply, then what will be on the AC contacts of the diode bridge?
    In theory, a diode bridge from a constant makes alternating current, something I'm completely confused :(:grin
    Perhaps I need to connect contacts to the AC from the power supply, and already output + and - to the driver as expected?
  12. Gadget999
    12,132Coins
    A bridge rectifier converts AC to Dc
    Your power supply already has one inside
    What you need is 2 diodes
    One to protect the positive terminal from reverse voltage
    And one on the negative terminal to protect reverse voltage
    Are you sure you need diodes ? The power supply may be ok
  13. kalbasator
    Kazahstan, Almaty
    170Coins
    Thank you for your recommendations. I found a post where they used bridge diodes and this helped solve the problem of regenerative energy from motors https://www.xsimulator.net/communit...mms-and-arduinos-osw.6948/page-31#post-117116
    Therefore, I decided to do the same for myself, but from the information received I got confused about what to connect where:)
  14. kalbasator
    Kazahstan, Almaty
    170Coins
    So I think it will be right, now if someone else confirmed this:
      201.9 KB
      359
  15. kalbasator
    Kazahstan, Almaty
    170Coins
    In general, after the research, I found three options, two from @BlazinH and one from @Pino Pistolidas, all three work according to the authors.
    That's why I'm thinking about which one I'll use.
    The only confusing thing about the Pino Pistolidas example - is that using both AC terminals doubles the current.
  16. kalbasator
    Kazahstan, Almaty
    170Coins
    So, I figured out the diode bridge, but how to connect the resistors?
    I made a diagram, who can tell if it is correct for my case?
  17. kalbasator
    Kazahstan, Almaty
    170Coins
    Hello! I have some updates.
    Yesterday I started setting up motors via SMC3utility. I set up the pots (On all motors, the green line tends / moves towards the blue one, this is good :)).
    But there is a problem - when I move the cursor to the bottom "in manual mode", then motor 1 also moves down, but the second motor 2 moves up:confused:.
    I have an idea why this is so. I think I need to swap pins B1 and B2 on the bridge / motor driver that go to Arduino in pins 4 and ~ 5.
    I don't see any other options, because if I change + - on motors or on GND +5V pots, then the green line goes away from the blue line ...
    I also read somewhere on the forum that in the code you can infer, change the direction of the axis (make a reverse), but I can’t remember in which post it was.
    Or maybe just move the pot to the other side of the motor?
    Although no, the motor then receives a command where to rotate and the pot simply monitors whether the shaft has reached the specified place.
  18. Gadget999
    12,132Coins
    Its ok, it is working correctly
  19. kalbasator
    Kazahstan, Almaty
    170Coins
    And so, after six hours of manipulation with wires, my strength and mood began to leave me, nothing helped. Finally, I just moved the pot to the other side of the motor and everything worked as it should! I can’t say exactly what helped, but at the moment all the motors are moving where they should be and I am very happy about this!
    Next, according to the plan, set the optimal parameters in SMC for my motors, then set up the SimTools and only after that again disassemble everything, paint...
  20. kalbasator
    Kazahstan, Almaty
    170Coins
    Hi all! I synchronized all the motors and everything moves as expected. I also did output testing in SimTools and everything is moving as expected there too.
    Now that I'm convinced that everything is in order, I want to set the optimal parameters in SMS 3 Utilities for my motors...
    I have motors 300Watt 24V 12.5A, reducer 50:1, pots 360g, Chinese H bridges 100A
    @noorbeast is there any minimum recommendations for SMS 3 Utilities settings? Or is it customizable by experience? If I exceed the PWMmax parameters, can something burn out on me?
