2dof project with car windshield motors
Discussion in 'DIY Motion Simulator Projects' started by nmk, Jul 19, 2022.
  1. nmk
    nmk New Member
    61Coins
    2DOF, 3DOF, DC motor, SimAxe, Arduino, Motion platform
    I put two car windshield motors used the arduino and the drivers for the motors.
      115.8 KB
      305
      94.5 KB
      296
  2. nmk
    nmk New Member
    61Coins
    I would love to be able to help everyone and learn too thank you very much.
  3. nmk
    nmk New Member
    61Coins
    12 volt car windshield motors don't have much power so my tip would be 24 volts.
    154,448Coins
    +11,181 / 57 / -2
    Interesting motor placement, how do they respond under load?
    What drivers and code are you using with your rig?
  5. nmk
    nmk New Member
    61Coins
    good morning, the motors respond well but the chair must be in a well balanced angle because if you put all the weight of the body, the motor does not support all the weight, the drivers I'm using IBT-2 and the code I'm using the SMC 3 and the source is using a Silver Stone 750W model SST-ST75F-PT.
  6. nmk
    nmk New Member
    61Coins
    154,448Coins
    +11,181 / 57 / -2
    When you get a free moment it would be great to see a video of your rig in action.
  8. nmk
    nmk New Member
    61Coins
    hi my project is still not well regulated so when i finish it i will post a video yes, but now it is not very well regulated maybe i need to review it.
    154,448Coins
    +11,181 / 57 / -2
    See the motion tuning Tips in the FAQs, they will likely help you regulate your rig: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    If you are still struggling others can make motion tuning suggestions if you post pictures of all of your settings and a video that shows the game screen and rig moving at the same time.
  10. nmk
    nmk New Member
    61Coins
    hi good afternoon I bought some pieces and I'm waiting to arrive thank you very much, as soon as it's working normal I'll post a video, I'll check the post on the forum thank you very much.
  11. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    Hi, is it a PC power supply that you use? I had problems with 2 power supplies lately and I would like to know your feelings
