fox2022
Forza Horizon 5 Plugin 2022-04-20
  1. fox2022
    fox2022 New Member
    479Coins
  2. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    THANKS!
  3. fox2022
    fox2022 New Member
    479Coins
    Hi ,I updated the Plugin, the DashBoard and the GameVibe may work in this version,but I can't test it because I don't have these devices:(.I think the signal from the UDP is to small so I set the data more bigger in this plugin.
    so,you can set to appropriate values with your controller. Enjoy!
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    it works ! tks
  5. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    Anyone have issue with this plugin providing roll? I have motion in grid, Horizon 4, forza Motorsport 7 and horizon 5 but only horizon 5 seems to have limited motion
    Any suggestions?
  6. lVlemphiz
    Automotive Engineer
    252Coins
    Hard to buy this explanation since every other game functions differently/ appropriately...
    My motion rig vendor provided a different plugin that's working a lot better
    153,812Coins
    +11,150 / 57 / -2
    Can you please provide pictures of the Tuning Center while the game is running, that will establish if roll data is present or not, or if it is a user configuration issue.
  8. lVlemphiz
    Automotive Engineer
    252Coins
    It was an issue on my end. An adjustment to the values in the tuning center fixed it with this plugin as well. Thank you
  9. lVlemphiz
    Automotive Engineer
    252Coins
    Anyone ever see their heave motion disappear in full screen? I've replicated this numerous times. No heave full screen but if I window it then I have heave
  10. lVlemphiz
    Automotive Engineer
    252Coins
    To follow up for future ref...
    Uninstall and reinstall of Simtools fixed this issue. Must have been a bug not sure.
  11. Alessandro TheDarkness
    Alessandro TheDarkness New Member
    - 55Coins
    hi guys! Anyone feeling the roll as inverted? Playing the hotwheels tracks, when the track is tilted to the right, the motion system tilt to the left. Is there some way to invert that? Thank you!
  12. yobuddy
    51,530Coins
    Use the Dir check box's in axis assignments page to flip direction.
    Take care,
  13. el_marius90
    el_marius90 Simracer simulador 2dof
    Electricista
    Madrigueras
    - 928Coins
    Hi, I think I'm doing something wrong when patching, how it says the ip and port, I don't know if I'm doing it correctly, could you help me
  14. GerarLM
    GerarLM New Member Gold Contributor
    - 44Coins
    Hi, I installed ForzaHorizon5_GamePlugin.V2.0.0.0bykai.zip and I configured:
    Udp output Ip:127.0.0.1
    port:4123
    But I have not motion. I also have Asseto Corsa and motion works well with it with but Forza Horizon 5 doesnt works.
    This is a screnshot of Tuning Center running Forza Hotizon 5 (it doesnt work):
    And this is a screenshot of Tunning Center running Asseto Corsa (it works well):
    Could you help me?
    Thanks a lot.
  15. paulopsx2
    brasil
    647Coins
    maybe the same plugin for new forza motorsport?
  16. linkostex
    linkostex New Member Gold Contributor
    - 14Coins
    I can confirm that this plugin is working very well with the new Forza Motorsport.
    You just need to activate the telemetry in the game settings with this settings
    Ip 127.0.0.1
    Port 4123
  17. paulopsx2
    brasil
    647Coins
    hi... how can i run f5 horizon plugin on new forza?
    if i clcik on fh5 plugin simtools just try to access fh5 on steam !
    and if i try to access forza 8 exe on c: windows says im not adm ( but i am rs )
    even in adm, windows says im not access for f8 exe file. i try to give permissions on properties
    but nothing happens.
  18. linkostex
    - 14Coins
    I'm using this plugin for Forza Horizon 5
    https://www.xsimulator.net/community/threads/forza-horizon-5.16649/
    You don't need to change anything in simtool. Just click the play button on the game manager to run the plugin.
    In Forza Motorsport activate the telemetry (just change ip and port according to my first post) and it will work
    No need to patch the exe file
  19. paulopsx2
    brasil
    647Coins
    Dont work. Just like a say above, if i just click on play in plugin, simtools v3 try to open forza horizon 5 on steam.
  20. linkostex
    - 14Coins
    My forza horizon 5 was the Microsoft store version.
    Maybe it's the reason why your (steam) version is trying to star when you click the play button.
    It could be a patching problem in simtool
    I just played the new Forza right now. it's working very well with this plugin
