Suglock's configuration issues
Discussion in 'New users start here - FAQ' started by noorbeast, Jul 30, 2022.
  1. noorbeast
    152,235Coins
    +11,066 / 56 / -2
    Grab a copy of the vSimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    The Dir being checked orange or not in Axis Assignments determines which way each axis moves, so it sounds like you have sway reversed.
    It is had to comment on surge without knowing your settings, so best to post pictures of all of your settings, including the Tuning Center while the game is running.
    152,235Coins
    +11,066 / 56 / -2
    Seems you are posting motion profile issues i multiple places with respect to multiple games: https://www.xsimulator.net/communit...-competizione-plugin.12426/page-5#post-230305
    That suggests you don't have a sound Default profile configured, which can then be duplicated and tweak for specific games.
    Please post pictures of all of your settings on your own dedicated project thread, including the Tuning Center while the game is running.
  3. Suglock
    Suglock New Member
    46Coins
    Hello
    As you want
    Thx for your help
  4. Suglock
    Suglock New Member
    46Coins
    Hello
    My set-up as ask
    Thx for your help
      174.8 KB
      316
      172 KB
      233
      122.8 KB
      224
    152,235Coins
    +11,066 / 56 / -2
  6. Suglock
    Suglock New Member
    46Coins
    Photos of my configuration because I don't know if I'm doing well in my settings I only have two jacks.
    152,235Coins
    +11,066 / 56 / -2
    Thanks for the clarification.
    So for 2 actuators you only need Axis1a and Axis2a configured, not all of theses:
    Because you have a 2DOF rig it has to share its full movement range (100% of its physical movement) between different axis. That is the purpose of the Axis Assignments, how much each of the movement rage each axis is allocated. Your current allocations are way too high, as the total is way more than the total movement range your axis can provide.
    If you read through the earlier posts FAQ profile tuning tips it suggests you start at around 20% and then adjust from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Likely Roll, pitch and sway will end up with an Axis Allocation over 20%, surge likely around 20% and heave much less that 20%, likely 10% or under. In reality the total allocation can be a little over the 100% of the actual actuator range, as it is rare all axis are at their maximum values at the same time, except in a crash.
    Initially tuning should be done one axis at a time, temporarily disabling all other axis.
