value1
GRID (2019) Plugin 2.0.0.2
SimTools plugin for GRID (2019)
  1. noorbeast
    152,235Coins
    +11,066 / 56 / -2
  2. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
  3. yobuddy
    51,074Coins
    Check your 'My Games' folder in your documents, I bet there is a grid folder found there that you can patch too.
    Take care,
  4. lVlemphiz
    Automotive Engineer
    252Coins
    I had to run a full race first for it to show up in My Games. I missed that part.
    Got it working now. Thank you everyone
  5. lVlemphiz
    Automotive Engineer
    252Coins
    Anyone have an issue with the heave motion in this game being weak? My PC reset and it seems I don't have heave only in this game. Not sure what's going on. Anyone have any suggestions? I tried uninstalling the game and patch but it's not helping.
    152,235Coins
    +11,066 / 56 / -2
    Have you refined your motion profile, in particular for heave, see the FAQ tuning tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  7. lVlemphiz
    Automotive Engineer
    252Coins
    Yep I made the mistake of not doing this with Horizon 5 so I did make sure to check that box. I'm only using the default layout and tuning from there.
    What's weird is it's the only game not giving full motion but it didn't have this issue before my PC reset and I had to reinstall everything. Same PC, same settings, same motion rig but something is different with just Grid 2019.
    I tried reinstalling the game, sim tools and the plug in
    152,235Coins
    +11,066 / 56 / -2
    Games need settings dialed in individually, so temporarily set all axis except heave to zero in Axis Assignments, then dial in the heave setting in Axis Assignments and in the Tuning Center.
  9. lVlemphiz
    Automotive Engineer
    252Coins
    I'll do it again but I did do the tuning. The problem is nothing seems to be affecting the heave motion. Is there a reason why my tuning settings from before are now not providing any noticeable motion in one direction? Does that typically happen?
    152,235Coins
    +11,066 / 56 / -2
    Depends, it could be a hardware related issue.
    But please post a picture of the Tuning Center while the game is running, that will establish if heave data is working, if it is configuration should sort it out.
  11. lVlemphiz
    Automotive Engineer
    252Coins
    These are my settings in the tuning center with the game running
    152,235Coins
    +11,066 / 56 / -2
    That shows no game data at all, which would mean no motion on any axis, did you start a race?
  13. lVlemphiz
    Automotive Engineer
    252Coins
    Yea I was in the middle of a race. I'm definitely getting motion though. You can see the blue button in the corner. I'm getting motion just not heave and the motion is kind of weak. Only this game
    152,235Coins
    +11,066 / 56 / -2
    There is no game data in the image you posted, so it can't be accurate if you have motion:
  15. lVlemphiz
    Automotive Engineer
    252Coins
    Any ideas what may be wrong then if the rig is moving despite that?
    I have to stop racing to take the snapshot so I'm not sure
  16. noorbeast
    152,235Coins
    +11,066 / 56 / -2
    Have the game running in a window, so that the Tuning Center can be seen at the same time, has data, and take and post a picture of that.
    I expect if heave data is present you can set heave somewhere around 0.5 - 1 in the Tuning Center you will feel it, and will be able to tweak from there.
  17. lVlemphiz
    Automotive Engineer
    252Coins
    I can window it. I think I can delay the snapshot long enough to unpause the game, drive and capture the data
    I'll try it; thanks
  18. lVlemphiz
    Automotive Engineer
    252Coins
    Looks like the output is on a super small scale...not sure why.
    152,235Coins
    +11,066 / 56 / -2
    The reason is likely that the car is on pretty level ground with small axis movement.
    Heave data is present, so use a lower value for heave in the Tuning Center to sharpen the heave motion.
