F1 2022 v1.0
F1 2022 GamePlugin for SimTools
  1. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    Arduino, Motion platform
    I was able to get SimHub and SimTools to work for F1 2022 without installing a proxy server. Took me all day but it ended up being pretty simple in the end. Let me know if I can help.
    151,449Coins
    +11,038 / 56 / -2
    For the benefit of others can you please detail what you did and what you learned?
  3. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Im working perfect too within proxy.
    I Just use a New port on f1 22 game and redirect the loopback ip on simhub to 4123 ( simtools port )
  4. Suglock
    Suglock New Member
    46Coins
    Thank you but that's what we do except that to have correct movements it is necessary to configure the telemetry on the udp 2018 format and that for the telemetry for the dash etc work only on the udp 2022 format and that simtools under this format does not work not...
  5. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    Not a problem.
    * You need to go to the F1 Game in the telemetry settings. Change the UDP Port from 20777 to 20778. Exit to main screen and quit game.
    * Open SimHub, go to games and game config F1. Change game telemetry UDP port to 20778
    * Check the box under UDP Forwarding and keep that at 20777.
    * Next go to settings and Plugins tab, scroll to the bottom and you will see on the last line, UDP Relay, turn this button on.
    * This will place a UDP Relay option on the left column, select that option.
    * Change the source UDP Port to 20778, leave the target IP, and make sure the Target UDP Port is 20777. Hit the apply now button.
    * I closed out of SimHub, opened SimTools Game Manager and reopened SimHub. I started F1 through SimHub, both SimHub and SimTools worked seamlessly.
    I hope this helps and let me know if you have questions.
  6. Suglock
    Suglock New Member
    46Coins
    Wish udp format please in game because only the 2018 work for simtools and this case the dash doesn't work because the udp format selected to 2022
  7. paulopsx2
    brasil
    647Coins
    2022 only works on New simtools v3 ( alpha Project)
  8. Suglock
    Suglock New Member
    46Coins
    Ha OK I prefer because simtools doesn't works with this udp format..
    When the release for the v3 please because I like play with this version to f1 2022
  9. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    I didn't change it, it is still 2022
  10. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    I have the latest SimTools and SimHub. I did the steps I posted and it work without problem on the 2022 UDP format.
  11. bruno1210
    bruno1210 schumi06
    103Coins
    release the alpha version of simtools v3
    151,449Coins
    +11,038 / 56 / -2
    No the closed Alpha will not be released, it is for testing and bug identification. But hopefully a more widely available Beta is getting close.
  13. bruno1210
    bruno1210 schumi06
    103Coins
    thank you for the answer .
  14. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Same with Sim Dashboard. Have to change the port to 20778 in the game, and then forward the port in Sim Dashboard to Game Manager's 20777 port. Had to run in 2018 telemetry to get the right signals to gamevibe tho.
  15. Roons
    Roons New Member
    - 20Coins
    Motion platform, 6DOF
    Is anyone else seeing negative values for Pitch when going up Raidillon on Spa?
    I'm seeing strange Pitch values on many of the tracks such as sometimes being positive for down hill sections and negative for up hill sections and it seems pretty random. Sometimes correct, sometimes not. All other axes appear to be fine, its just impacting Pitch.
    :think
  16. noorbeast
    151,449Coins
    +11,038 / 56 / -2
    To confirm you could try temporarily disabling all other axis by setting zero as ethe Axis Assignment for them, and test just the pitch axis, to rule out other potential configuration issues.
  17. Roons
    Roons New Member
    - 20Coins
    I tested as you described and Pitch is still showing as a negative value when going up up Raidillon on Spa causing the platform to pitch forward instead of backwards like it should when going up hill. The issue appears to be on random hills, pitching down (negative pitch telemetry) when it should be up and sometimes pitching up (positive pitch telemetry) when it should be down.
    Does anyone see this specifically on Raidillon on Spa? I just want to confirm for my sanity as I think its an EA bug vs the plugin.
    Thanks!
  18. noorbeast
    151,449Coins
    +11,038 / 56 / -2
    The plugin works off game data and the Axis can be set for one direction or the other in Axis Assignments with the Dir setting being either checked orange or not.
    The only other SimTools side possibility is ensuring the computer is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  19. Roons
    Roons New Member
    - 20Coins
    Thanks for the help noorbeast! The game data is broken and reporting the wrong pitch values. It's an issue with EA and the game and appears to have impacted at least the last 3 titles: F1 2020, F1 2021, and F1 22.
    It's easy to consistently replicate the pitch issue by going up Raidillon on Spa. The buggy pitch telemetry is on every track sometimes working correctly, sometimes not.
  20. Nocelo
    Nocelo New Member
    45Coins
