FlyPT Mover 3.5.3
  1. Roller2525
    Roller2525 Member
    220Coins
    Hey @pmvcda!
    Thanks so much for the update! Please don't ever feel you need to give a reason why your work on Mover has slowed a little lately.. Life is crazy for many of us in this current world I'm sure.
    So good to hear though that you are still working on it! That is awesome.
  2. DerKlausi
    DerKlausi New Member
    117Coins
    Hi all,
    I've been trying to output FlyPT Mover to SMC3 Tools via UDP but just can't get it working. IP address (127.0.0.1) and port (20017) are correct (have previously been working with other software).
    What happens:
    1. Launch SMC3 Tools, then try to connect Mover: Mover complains it can't initialize UDP connection.
    2. Connect Mover, then launch SMC3 Tools: SMC3 Tools will crash without error message at the moment the GUI appears.
    Any ideas and suggestions how to get them to play together? My aim is to monitor motors when fed by a 'synthetic' source, that is - a sine wave loop source in Mover, which is working nicely when using serial output. But then SMC3 Tools won't launch, I assume due to a COM conflict.
    Any help is much appreciated!
  3. pmvcda
    15,702Coins
    The same com port can only be accessed by 1 software, not 2 at the same time.
    If you connect with Mover, you can't connect with smc3 or the other way around.
  4. DerKlausi
    117Coins
    Thanks, that's why I was trying to connect via UDP instead ;-)
    Any idea why that did not work out as described above?
    Thanks,
    DK
  5. stil550
    stil550 Member
    USA
    310Coins
    3DOF, Arduino
    Hey everyone, wanted to ask...
    Is it feasible to use FlyPT as a controller for a DIY force-feedback joystick?
    Since FlyPT offers the ability to use "Direct" which would control one specific motor, I'm thinking if I can connect FlyPT to two separate motors and have two "Direct" nodes in FlyPT, I should be able to effectively control at least the spring force of the joystick in X and Y and base it off the aircraft's speed.
    I'm a complete noob to the electronics though, so may be completely talking out of my ass on this one.
    Has anyone tried anything like this?
  6. Avee
    Avee Virtual Pilot
    1,167Coins
  7. Roller2525
    Roller2525 Member
    220Coins
    Hi guys
    Wondering whether this is the correct sequence to apply a spike filter? I am wanting to cancel out anything over a value of 3.
    SPIKE(LOGISTIC(EMALP(EMAHP(VALUE;1500);200);3;0.2);3.5;1;2)
    *Applies to longitudinal acceleration
  8. Roller2525
    Roller2525 Member
    220Coins
    ...hmmm, well that didn't achieve what I wanted it to do. Anybody have an idea how I would cancel out the violent jolts when you hook up to the catapault in DCS? I could add more EMALP but then I lose the jolting effect of the launch..
    *edit* seems reducing the emahp to 400 has helped.
  9. Daboh
    Daboh New Member
    41Coins
    3DOF, AC motor, Arduino
    Hi, I am new here. I have started a year ago with sfx100 and simfeedback. I am currently in the process of upgrading the rig for flypt mover. Until I have the controller ready, I am currently playing with the setup of flyPT Mover, and I am already so far that everything should work. I have been experimenting with the joystick input and I have two questions to better understand flyPT Mover:
    1. How can I get the rig to hold the position I input with the stick? Currently, the rig changes position when I move the analog stick and then returns to the neutral position even though my stick still has the angle. Currently, I do this via the pose DOF FROM VALUE.
    2. With the pose FROM NOISE GENERATED BY VALUE I noticed that the rig no longer returns to the neutral position. Is this so habitual? How can I prevent this?
    Cu Daboh
  10. Historiker
    9,205Coins
    If you are using a high pass filter it will return to neutral, how fast depends on what you have the filter set at.
  11. Roller2525
    Roller2525 Member
    220Coins
    I always thought a higher number ie. 2000 for an EMAHP demanded a slow return. In this case it seems to make the jolts more severe.
  12. SilentChill
    20,601Coins
    with EMAHP you will be letting all trhe spikes through, try EMAHP 50
    or just try with standard EMA at 500 ? I dunno as I havn't tried DCS properly
  13. eduardo.magnetto
    eduardo.magnetto New Member
    Buenos Aires
    83Coins
    Hi! New to FlyPT. Is it possible to use it offline (no Internet access).
    I´m getting a .NET error after starting it.
    153,866Coins
    +11,152 / 57 / -2
    Can you please post a picture of the full .NET error.
  15. deadlymanager
    deadlymanager Member
    11Coins
    Just twice ignore this error and all be fine.
  16. eduardo.magnetto
    Buenos Aires
    83Coins
    That´s what I´m doing. But its not a nice solution, specially if I want to minimize interactions to start a simulation.
    Thanks anyway!
  17. eduardo.magnetto
    Buenos Aires
    83Coins
    Check image and the complete message below.
    Thanks!
    System.Net.WebException: The remote name could not be resolved: 'flypt.dynip.sapo.pt'
    at System.Net.WebClient.UploadValues(Uri address, String method, NameValueCollection data)
    at Mover.Setups.SaveSharedSetup.Exists()
    at System.Windows.Forms.Control.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Form.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at Mover.BaseForm.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    FlyPT Mover
    Assembly Version: 3.3.4.0
    Win32 Version: 3.3.4.0
    CodeBase: file:///D:/Software/FlyPT%20Mover/FlyPT%20Mover.exe
    System
    Win32 Version: 4.8.4536.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    MySqlConnector
    Assembly Version: 1.0.0.0
    System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
    System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  18. hannibal
    hannibal Active Member
    4,492Coins
    im just learning now about washout.. i needed this!
    are you still around @pmvcda ?
  19. Erik Green
    Erik Green Member
    409Coins
    Looking at the kinematics of a 2DOF Linear seatmover I'm wondering why one cannot include Yaw? I know this is not a Mover specific question, but I intend to you Mover and was thinking this would be a way to get some rear traction loss.
    153,866Coins
    +11,152 / 57 / -2
    Just to clarify, Yaw as an axis rotates around a center point of the rig, while Traction Loss relies on a pivot point somewhere near the feet, so they are very different. A 2DOF seatmover is not capable of either.
