Question Problems with 2 Axis of a 6DOF System
Discussion in 'SimTools DIY Version' started by sci666, Aug 17, 2022.
  1. sci666
    1,210Coins
    Hello there, finally i start to setup my 6DOF Simulator the first time
    i was able to wire up everything correct. i have a 6dof with 3 Arduino uno and 3 Sabertooth Modules.
    so i have COM5 + 6+ 7
    in SMC3 tool every Arduino works as it should
    COM5: Motor 1 and 2
    com 6 Motor 1 and 2
    com 7 with motor 1 and 2
    i have to setup all values to the same later but fot testing it works !
    so all motors moving with the test values or in manual mode as they should !
    BUT in Simtools Engine i have Problems with COM7. these 2 motors doesnt work as they should they randomly go up and down ... i dont know what it is: config for test:
    Interface settings for the 3 Ardunios:
    all the same with different Axis :
    Interface 1: [A<Axis1a>][B<Axis2a>] works fine
    Interface 2: [A<Axis3a>][B<Axis4a>] works fine
    Interface 3: [A<Axis5a>][B<Axis6a>] does not work !
    test with roll and Heave:
    Axis 5 and 6 does nothing else then randomly go up and down.i cant see a logic to the movements ...
    Does anybody have an idea whats going on there ????
  2. Gadget999
    12,132Coins
    Swap the usb ports and usb cables over
  3. sci666
    1,210Coins
    i tried this before , does not work also swapped out motors and stuff.
    153,770Coins
    +11,149 / 57 / -2
    Set Output Bit Range to 10 on the com port 7 Interface settings.
  5. sci666
    1,210Coins
    Argh... Iam so stupid. Didnt noticed this difference. Ill try it tomorrow I hope it works
    153,770Coins
    +11,149 / 57 / -2
    It is easy to miss and many of us have had similar experience at some point in our projects, which is why it is good to have an active community to bounce stuff off.
