OpenXR Motion Compensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by SilentChill, Aug 6, 2022.
  1. SilentChill
    20,567Coins
    Hi all,
    OpenXR Motion Compensation is in alpha testing ans is looking very promising :) I did a quick video with it in action.
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,748Coins
    This are verry good news!! Can you tell us a little bit about setting up the software for the first time and at each start of a sim-session?
    Thanks!
    Wickie
  3. SilentChill
    20,567Coins
    Hi matey,
    It's only in Alpha at the moment so it's just getting it working properly. The dev is going to make it all pretty and easy to use.
  4. Historiker
    9,207Coins
    Once again, you are my Hero buddy!
    The others in my squadron have all moved to OpenXR for DCS but I have been relegated to SteamVR for motion compensation. Thanks for bringing this to my attention. I took forward to the beta!
  5. Michael Mariacher
    Michael Mariacher Member
    632Coins
    4DOF
    Once again, a STEAM VR update broke OVRMC. (But luckily I found a way to solve... ) :thumbs
    After some days off, I got Build ID 9276252 and OVRMC did not load, same issue as some days ago.
    Enabling actual Beta made it even worse
    After restarting, well known message "Add on blocked"
    After several worthless restarts, I decided to op into "old" V1.21.12 hotfix.
    This "Beta" solved the issue, OVRMC is starting again and works flawless.
    But I fear the next update, it's just a matter of time STEAM will again "f**k up" OVRMC. :(
    Michael
  6. SeatTime
    28,320Coins
    Got this also last night . Thanks for the solution :thumbs
  7. SeatTime
    28,320Coins
    Yep, fixed it. FI I am using the WIT 9 axis sensor (SRS). For me, find it way more reliable then the lighthouse solution, but it is limited to using SRS.
  8. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    flypt work with WIT 9 axis sensor.
    • Informative Informative x 3
  9. SeatTime
    28,320Coins
    Thanks, must investigate.
    • Old Old x 1
  10. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I can't find it anywhere where they write about it in flypt , but when I fly in msfs + OVRMC+WIT 9 axis sensor without steam everything works properly.I don't use any motion controls.
  11. SilentChill
    20,567Coins
    OVRMC or OXRMC ??
  12. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    OVRMC
  13. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    so sorry for the introduction .here is how it works with flypt for me it's ok I'm happy with flypt and OVRMC. https://www.flyptmover.com/outputs/ovrmc
  14. SilentChill
    20,567Coins
    So youre using OpenXR and OXRMC its just that the plugin for Mover is still called OVRMC it uses the same MMF .
    OVRMC only works with steamvr enabled to turn it on and off and calibrate it.
  15. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    yes you explained it right now i just found it.steam turns on automatically if i use openXR and OVRMC in flypt settings in Ouputs set to OVRMC.for me it works fine i'm more of a flying player than a racing player.in racing you definitely have more vibration.
  16. SeatTime
    28,320Coins
    Maybe it is just me :confused:, but cannot find a flypt source for a WIT sensor..
    That is using a virtual tracker, not a real tracker attached to the rig. Real tracker works way better for me.
  17. Chipless
    Chipless Member
    132Coins
    @SilentChill Any updates regarding OpenXR Motion Compensation?
  18. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    Hi @misoswan or others….just to clarify, has anyone found a solution to use WITMOTION tracker with xplane or fs2020? SRS doesn’t support any flying games. Thx
  19. SeatTime
    28,320Coins
    My version of SRS supports FS2020 and Xplane 10/11/12.
  20. sallerding
    sallerding Member
    344Coins
    Oh! Thx @SeatTime. Is that through the paid version or are there other modules that can be added manually? Is that something you prepared or something that can be obtained elsewhere? Thx . I have the tracker. If there was a solution available for flying that would be great. Thx for any info seatime
    edit….I think I see. You can use a motion profile for xplane or fs2020 through SRS, which looks like you can then open up the possibility of using the WITMOTION. But I guess thats what you mean when you say you can’t use flypt with it?
