Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. yobuddy
    51,549Coins
    Please goto:
    "C:\Users\(your user folder)\AppData\Local\SimTools\GameManager\GameProfiles\Profiles\"
    And delete the folder for the game.
    Then relaunch SimTools and see if it's corrected.
    Let me know buddy!
  2. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    It worked and i captured values, but the movement is once every minute and makes no sence. Dirt 1 is actualy quite good.
    153,962Coins
    +11,160 / 57 / -2
  4. yobuddy
    51,549Coins
    Maybe try using the same Max/Min settings you use for Dirt1.
    It would probably get you in the ballpark anyway.
    Take care!
  5. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    @yobuddy Hi. Is it possible somehow that u create new plugin for Richard burns rally? I see very big difference between Your plugin to dr2 and Richard burns rally plugin. Your is much more detailed, and work without problems and filters. Or is it a game problem? Thanks for your work
  6. yobuddy
    51,549Coins
    There is a new v3 plugin for richard burns rally loaded to the repo.
  7. darylbradygp
    darylbradygp New Member
    22Coins
    just want to know why I am not able to download the file?
  8. darylbradygp
    22Coins
    nevermind, got it. thanks
  9. Thieny3000
    Thieny3000 New Member
    - 34Coins
    2DOF, 3DOF
    hi sir. i am not download file too. can you show me how? thanks
    153,962Coins
    +11,160 / 57 / -2
