help with motors
Discussion in 'Ready, set, go - Start your engines' started by percival, Aug 22, 2022.
  1. percival
    percival New Member
    11Coins
    153,968Coins
    +11,160 / 57 / -2
    I am not sure which of the motors you are using, best to give the direct page and full motor specs.
    Motors are just part of the issue, the other big factor is design. You can use SimCalc to help work out the tradeoffs between design Vs physics and what motors are needed to drive a given design at a desired level of performance: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
  3. percival
    percival New Member
    11Coins
    thank you for your reply.
    My design should be something like thishttps://www.xsimulator.net/community/threads/2dof-with-24v-dc-motors-and-arduino-nano.5667/
    I was thinking of using Arduino Uno and IBT2 (or Sabertooth 2x32 if needed).
    For motors I only have this data MY1016Z3 350W 24/36V 3850RPM 1.11Nm.
    This is the link to the engines https://www.alatimilic.hr/shop/Reze...r za samogradnju elektro vozila MY1016Z3 350W
    Since I'm not particularly experienced, I'm not sure if they fit my design, so I'm asking for your help.
    Thank you in advance
    153,968Coins
    +11,160 / 57 / -2
  5. Gadget999
    12,162Coins
    get the most powerful motor you can afford - make sure the gearbox has a ratio of 30:1 to 60:1
  6. RGS-Furtwangen
    RGS-Furtwangen GWS-Lörrach
    School
    Lörrach
    194Coins
  7. percival
    percival New Member
    11Coins
    then I order the engines and slowly move on
  8. ockert engelbrecht
    ockert engelbrecht New Member Gold Contributor
    - 245Coins
    2DOF, 3DOF, DC motor, AC motor, Joyrider
    Find out by the gate ore garage door installer close to you (I'm also installer and I done myne cheap)
    1 way ) DC 24 volt electric motor for a sectional ore tip-up garage door operator. make sure the gears is brass and not plastics .
    2 way ) best way :24 volt gate motors , 1-60 ratio motor gearbox with a motor input flange to join them .(will need engineering works to join them )
  9. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    Do you know wattage and rpm of the tip-up garage door motor?
