Showroom DIY 3dof Dbox Style Rig with 4 x 750 Watt Linear Actuators 100 mm
Discussion in 'DIY Motion Simulator Projects' started by Ringorumble, May 10, 2018.
  1. vulbas
    vulbas Active Member
    france
    1,102Coins
    AC motor, 6DOF
    Hello.
    I am building mine.
    thank you for all the work you have done.
    my only regret, not being able to use simtool with the arduino card
  2. sci666
    1,210Coins
    hi there, are 750watt servo motors really needed ??? i mean a worm gear sim rig with levers works with 120watt Motors. 750 for a linear one is so much over the top, isnt it ? whats the minimum servo recommended ? the electricity bill will thank you :D
  3. Thanos
    Electronics Engineer
    2,901Coins
    Its 750watt at 100% load. These can go for up to 300% load without tripping...
    Under normal operation you get from 30w to 100w ( unless you crash a lot...)
    https://youtube.com/shorts/igyFa4nO3UA?feature=share
