homemade 2dof motion simulator made with scraps
Discussion in 'DIY Motion Simulator Projects' started by CAI_77, Jul 9, 2022.
  1. noorbeast
    151,479Coins
    +11,041 / 56 / -2
    Set the Output Rate to 10:
  2. CAI_77
    CAI_77 Member
    67Coins
    2DOF, DC motor, AC motor, Arduino, Motion platform
    I finally made it!! I've been struggling all day since I got back from work, thank you really noorbeast you're a genius
  3. CAI_77
    CAI_77 Member
    67Coins
    hello, the steering wheel of the simulator was very high after the modifications of the seat and steering wheel, so I decided to fix that
  4. CAI_77
    CAI_77 Member
    67Coins
  5. CAI_77
    CAI_77 Member
    67Coins
    IMG_20220812_173803572.jpg again to cut, I got gas pipes a little bigger than the ones I had so I cut three pieces of 30 cm to adapt the structure and be able to raise and lower the steering wheel
  6. CAI_77
    CAI_77 Member
    67Coins
  7. CAI_77
    CAI_77 Member
    67Coins
  8. CAI_77
    CAI_77 Member
    67Coins
    after sanding and refining the base of the steering wheel it was as I wanted, now I can raise and lower the steering wheel of the simulator, I am very pleased with the result IMG_20220812_183904031.jpg
  9. CAI_77
    CAI_77 Member
    67Coins
    hello, on my way to convert the simulator 2dof to 3dof I had to take the first step and go from motoshild to ibt 2 so I got ready to do it...
  10. CAI_77
    CAI_77 Member
    67Coins
  11. CAI_77
    CAI_77 Member
    67Coins
  12. CAI_77
    CAI_77 Member
    67Coins
    to connect the ibt 2 I used computer cables that I had disassembled and I began to solder all the connectors that I needed IMG_20220902_084706051.jpg
  13. CAI_77
    CAI_77 Member
    67Coins
  14. CAI_77
    CAI_77 Member
    67Coins
    once I had everything, I got ready to connect everything, bad luck that one of the potentiometers that I had previously put stopped working, so I had to change it IMG_20220902_143034823.jpg
  15. CAI_77
    CAI_77 Member
    67Coins
    after struggling all day I managed to make it work, it was like starting again from scratch to build the simulator, the next step will be to design the chassis for the third engine and convert from 2dof to 3dof I am getting closer to achieving it IMG_20220902_151455256.jpg
  16. CAI_77
    CAI_77 Member
    67Coins
  17. CAI_77
    CAI_77 Member
    67Coins
    Good day !! I try to patch the game and it tells me this, I don't know which folder is the one I should patch or put, if someone knows how to solve the error please I ask for help
  18. CAI_77
    CAI_77 Member
    67Coins
  19. CAI_77
    CAI_77 Member
    67Coins
    Hi friends !! I made many modifications in the simulator and I want to share them, I want to transform it into a 2dof with loss of traction and this is the path I am going, less to go WhatsApp Image 2023-01-26 at 20.15.47.jpeg
  20. CAI_77
    CAI_77 Member
    67Coins
    back to the pits and disarm everything again WhatsApp Image 2023-01-26 at 19.57.23 (1).jpeg
