Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.3.0.0 pointer update
  1. marcelomanzo
    marcelomanzo New Member
    Montreal, QC, Canada
    80Coins
    The yaw I identify srv vs spaceship is by summing all variables yaw, roll, pitch, speed + gforces, if they are 0, I swap to srv or vice-versa.
    @Wagnard I am wondering if you have another receipt.
  2. Shelmak
    Shelmak New Member
    20Coins
    It's curious this is happening since if srv change profile is done by the sum of all variables, it should not happen.
    Currently it's switching profile when I lower throttle and I decel the ship, but it is switching while ship is still decelerating, so... maybe we are pointing to an incorrect speed variable?
    It is working correctly on Horizons version, it happens only with Oddisey.
    @Wagnard what go you think?
    Thanks for your help, to both of you.
  3. SaintFrank
    SaintFrank Active Member
    Proces operator
    Nederland
    232Coins
    Awesome Nisch , I got data coming into the source module .:thumbs
    Just have to make some adjustments in my pose and rig modules and I'm ready for some space action.
    Thanks for helping me out hug:
  4. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    Danke!thanks!
  5. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,294Coins
    @marcelomanzo
    @Shelmak
    I do almost the same, I also add the ship speed.
    If Ship_Surge + Ship_Sway + Ship_heave + Ship_Pitch + Ship_Roll + Ship_Yaw + Ship_Speed = 0 Then we assume we are in SRV
    If you also include the ship speed, it should help. It won't be perfect.
    And yes, odyssey pointers vs Horizons does not give the exact same results. In odyssey, the SRV values are still in memory, so that it why it can get confusion for the profiles switching
    I will try to get a more precise pointer with the next update, maybe it will fix this.
  6. Wagnard
    Wagnardsoft
    5,294Coins
    Here is EDH and EDO pointers for update 13.
    • Like Like x 5
  7. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    65Coins
    Hello Wagnard, Hello everyone.
    I just downloaded the latest plugin and update 13 August 2022. the game is patching fine, but I have no movements in Tuning center. of October 2021 and therefore the update of the XML file for the month of August.
    I don't see what else to do, can you help me a big thank you.
    L.Fleur
  8. Dronneau.Y
    france
    65Coins
    Anyone for Elite?
    Game connects fine, but no movement in Tuning Center
  9. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    3DOF, DC motor, Arduino, 6DOF
    Please, describe every step you took to patch the game and what software you use to communicate with the game (Simtools, Mover). Maybe some screenshots of your settings? We may find some missing parts in your setup. Does your rig work for other games?
    When I was doing my rig, my calibration journey started at that post:
    6 DOF from scratch
    I was mostly using it for Elite. So, it may help... Or not.
    Pierre.
  10. Dronneau.Y
    france
    65Coins
    Hello Pierre,
    I use simTools, my platform already works for a long time and with all kinds of games. it has already worked with the SilentChill plugin. but Wagnard's connects well to the game but doesn't give me any moves.
    I unpatched the game then dragged the plugin into SimTools Plugin_updater, then I launched Game Manager and repatched the game.
  11. Dronneau.Y
    france
    65Coins
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    Unfortunately, I don't see what may cause your problem. All seems fine.
    Sorry.
  13. Dronneau.Y
    france
    65Coins
    No worries, maybe someone else will take care of my problem.
  14. Dronneau.Y
    france
    65Coins
    153,824Coins
    +11,150 / 57 / -2
  16. Wagnard
    Wagnardsoft
    5,294Coins
    This can happen sometimes when starting the plugin / elite. Simply re-launch the GameManager.
    For your problem, show me the content of your "C:\Program Files (x86)\SimTools"
    and the content of your EliteDangerous64_Offsets.xml
    Also is it for Elite Dangerous Horizon or Odyssey.
  17. Dronneau.Y
    france
    65Coins
    Hello Noorbeast,
    And this Bug only affects Elite Dangerous?
    All my other games work without this change.
  18. Dronneau.Y
    france
    65Coins
    Hello Wagnard,
    Here is the screenshot.
  19. Wagnard
    Wagnardsoft
    5,294Coins
    Ok this seems ok, now shoe me the content of your xml
  20. Dronneau.Y
    france
    65Coins
