SimTools v3 Alpha (Questions, Answers, Fixes, Show & Tell)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Mar 17, 2022.
Thread Status:
Not open for further replies.
  1. early_m
    early_m Active Member
    Chelmsford
    820Coins
    Win 10.
    I'll try again with antivirus disabled
  2. sardiusxu
    sardiusxu New Member
    143Coins
    4DOF
    It has been a while since the alpha edition released. I really wish the new edition could support RBR as the old 2.5 edition. Looked as if there are only 1-2 person doing the coding work, and they are spending less than 5 hours a week on this project.
  3. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hi all... Is possible download and try the SimTools v3 alpha version?
    I read that it can also be installed together with version 2.5.1 for those who already have it.
    I would like to be able to start testing it if it were possible :thumbs
  4. yobuddy
    51,215Coins
    True
    False - not even close. lol
    The next step is putting out a public beta of SimTools v3.
    - Which means making all the changes we want/need from the alpha version.
    - Some changes like the Interface API changing, means all of the interfaces needed to be redone.
    - Setting up the website, database, and so much more.
    - Testing and so on...
    It just all takes time, but we are getting close! :thumbs
    Take care!
  5. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    Motion platform, 6DOF
    Does Simtools v3 allow a per car/per game automatic detection like SimRacingStudio does by reading the shared memory? I'm really hoping I can set up a "surge" value per car... certain cars just break your neck (BMW M8, Corvette DP in iRacing comes to mind).
  6. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    I have a lot of experience in Graphic Design (both UX and UI)... let me know if you need help with the UI elements... Perhaps, 3.0 is fully skinnable, like the old MP3 players?
  7. yobuddy
    51,215Coins
    Yes, It will be fully skin-able by the time the beta is over. :thumbs
  8. yobuddy
    51,215Coins
    It knows what game you launch, so yes.
    It knows what car (or profile) to use, if the plugin can support Auto Profiling, yes.
    (the game announces what vehicle its currently being used)
  9. levers
    955Coins
    Hi @yobuddy,
    I forgot to ask/mention when looking again at the parking feature the axis labels in the alpha version are still 1a, 2a etc. Will these change to match the customised naming in axis assignments?
  10. yobuddy
    51,215Coins
    There really isn't enough space to write labels there, but maybe a popup name or something.
    (Like when you hover 1a the name pops-up and so on, It's the same thing with axis limiting page also.)
    Chat soon!
  11. yobuddy
    51,215Coins
    3D speed fans now up and running, just working on the form layout. :thumbs
  12. yobuddy
    51,215Coins
  13. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Is this still correct? I think therefore I just found the answer to my question
  14. yobuddy
    51,215Coins
    Yep!:thumbs
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Where is this tab?
  16. paulopsx2
    brasil
    647Coins
    after change settings on game vibe creator, try test and simtools v3 just crash !! anyone, @vthinsel, @yobuddy, knows something like this?
  17. yobuddy
    51,215Coins
    This is the next gui thing to get done.
    But after you click test settings, move the upper right slider around, and the little white circle with the X on it turns it off.
  18. Gerardo Rivera
    Gerardo Rivera New Member Gold Contributor
    114Coins
    I have MSFS2020 on disk need to know how to added to the simtoolsV3
  19. yobuddy
    51,215Coins
    Install the game from the disk, and make sure it's up to date.
    Then install the plugin in v3, just like you would do with the steam version.
    After the plugin is installed, drag the games .exe file over the game banner in v3, this will set the correct launch path to your version of the game. (not steam version).
    Then you are ready to give it a go.
    Take care,
  20. Gerardo Rivera
    114Coins
    Followed the instructions and works,
    Got a question for the betaV3 any manual available the reason is I’m a newbie with motion simulator. Just bought Njmotion SV-F and trying to fine tuning it right little roughy on the inputs from the controllers
Thread Status:
