Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.2.0 Pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,238Coins
    this is not the most recent XML. Latest is on post #626
    The date inside the XML should be : 2022 August-09
  2. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    65Coins
    OK that works! it's really too stupid of me, I just downloaded the latest plugin without making sure that the .XML was up to date. Sorry and thank you
  3. Wagnard
    Wagnardsoft
    5,238Coins
    XML pointers update for version 4.0 (only Odyssey needed them)
  4. Dronneau.Y
    france
    65Coins
    Thank you Wagnard,
    Personally, I use Horizons, I don't have any issues with ship movement, but I can't with SRV. what exactly should be set to true?
  5. Wagnard
    Wagnardsoft
    5,238Coins
    What do you mean you can't with SRV? There is no movement?
  6. Dronneau.Y
    france
    65Coins
    Yes that's it. no movements with the SRV even when setting extra 1 and extra2 to True.
  7. Dronneau.Y
    france
    65Coins
    whoops! everything seems to be working this morning. probably a bug in my PC. all my excuses. If I understand correctly, Horizons 4.0 should work with these pointers? I haven't installed it yet.
  8. Wagnard
    Wagnardsoft
    5,238Coins
    Well this is something complicated, because I have odyssey, it mean on my end that only horizon 3.8 is available. So I can't tell or test. But I guess it should work.
  9. Dronneau.Y
    france
    65Coins
    OK,
    I'll try that tomorrow.
  10. Dronneau.Y
    france
    65Coins
    hello,
    Indeed Horizons 4.0 works with the last update of the XML pointers.
  11. Dronneau.Y
    france
    65Coins
    small precision, does not work with the old XML, which means that it uses the Odyssey pointers seems to me?
  12. Wagnard
    Wagnardsoft
    5,238Coins
    Probably.
  13. jasod943
    jasod943 New Member
    - 132Coins
    Hello guys , i have horizon 4.0 but i got no motion .
    i'm lost , what plugin i need ?
    what i must do with xml file ?
    thanks by advance for your time
  14. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    I am also having trouble getting motion to work with Horizon 4 on Elite Dangerous.
    I have followed the advice I have found on the previous pages with no luck. I am new to the plugins so I may have made an error. But I Have followed the suggestions many times and feel I have done the correct process.
  15. Wagnard
    Wagnardsoft
    5,238Coins
    You must also apply the XML I posted a few post back
  16. ChuckyP
    Chicago, IL
    748Coins
    I did see the XML file. I think I have sorted the issue. I have a fractured steam installation that spans a few different drives. I reinstalled ED to the c: drive and everything is working for now.
    I appreciate the quick response.
  17. Wagnard
    Wagnardsoft
    5,238Coins
    Update 14 pointers
  18. George Dobransky
    Hungary
    - 43Coins
    Buddy,
    THX for your efforts, beer donaty has gone to you as usual....
    Cheers,
    George, HUngary!
  19. Wagnard
    Wagnardsoft
    5,238Coins
  20. SaintFrank
    SaintFrank Member
    Proces operator
    Nederland
    246Coins
    Thanks for the update :thumbs
    I updated pointers in flypt software, odyssey settings working for me and I only got horizons.
