Question Help for choosing 12V Motors for 2DOF
Discussion in 'Motor actuators and drivers' started by nils8107, Sep 15, 2022.
  1. nils8107
    nils8107 New Member
    21Coins
    Hello
    I want to build a simple 2DOF Rig for use with Flight Simulator 2020
    I`m Interestet in kind of this Motor: EBAY:
    GEAR MOTOR 12 VOLT GREAT FOR SAWMILL/CRAB POT PULL/FEED/SIMULATOR 75-80RPM 50:1
    Problem on Ebay it would cost me around 500USD with shipping and Tax to Switzerland.
    I want to use IBT-2 Motor controllers.
    Can anyone recomend me 12V Motors?
    Perhaps Aliexpress, or some European site?
    Thank you very much
    153,956Coins
    +11,160 / 57 / -2
    Secondhand electric wheelchair motors may be a better local option, if you can find some, they are quite powerful.
  3. nils8107
    nils8107 New Member
    21Coins
    Hello. Thank you very much.
    Do you think this would be good for a beginner rig?
    I want the 12V/250W version.
    MY1016Z2 electric vehicle motor 250W/350W deceleration brush motor
    Applicable models: MY1016Z
    Rated voltage DC: 12V/24V/36V
    Rated output power: 250W/300W/350W
    Rated speed: 3000r/min
    Reduction ratio: 3000r/mir
    Rated output torque: 8N.m-11.2N
    Efficiency: 78%
    https://www.aliexpress.com/item/100...816632365817815554e3718!12000017903185383!rec
    Thank you very much
    153,956Coins
    +11,160 / 57 / -2
    You should really clarify what design 2DOF you plan on building, you can then use SimCalc to work out motor specs to drive that design at a desired performance level: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    A shoulder mount seat shaker design has lots of inherent design leverage and can be driven with smaller motors, a compact design and heavier full frame knee mount designs often need a lot more torque from motors to drive them properly.
  5. nils8107
    nils8107 New Member
    21Coins
    153,956Coins
    +11,160 / 57 / -2
    That is a compact design you are planning so you will want good torque, something like Jazzy wheelchair motors or like the specs of model# 15 in this list:
  7. nils8107
    nils8107 New Member
    21Coins
    Thank you very much for this list.
    So I need around 50 rpm. and 300w power.
    I made some research but very difficult to find this things.
    Do you know where I can purchase this kind of motors?
    I want to spend if possible 300USD for two motors.
    Regards, Nils
    153,956Coins
    +11,160 / 57 / -2
    If you look around as per earlier advice Jazzy wheelchair motors on the likes of Ebay will probably be the cheapest and best local option: https://www.xsimulator.net/communit...oosing-12v-motors-for-2dof.17308/#post-231471
  9. nils8107
    nils8107 New Member
    21Coins
    Thank you
    I have now orderd two motors
    "GEAR MOTOR 12 VOLT GREAT FOR SAWMILL/CRAB POT PULL/FEED/SIMULATOR 75-80RPM 50:1"
    416USD incl shipping and some import tax will follow...
    Thanks everyone
  10. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    I've ordered two 250W 75rpm wheelchair motors from a Cina manufacturer.
    150 Euros including shipment and taxes, don't know what to expect for customs fees though
