FlyPT VR-nonVR different motion IN Values
Discussion in 'Flight Simulator 2020 - FS2020' started by gaco, Sep 20, 2022.
  1. gaco
    gaco New Member
    195Coins
    Yesterday I realized when I switch to VR my Rig gain changes and my Rig moves.
    I have to disconnect from MSFS under VR and connect again. Then it works 80%.
    The Simconnect output Values do not change, only the Input values in FlyPT changes by around half the value when I switch to VR. When switching back it´s like it should be.
    What is this causing?
    Sometimes I do not get motion when on ground after landing. Happens randomly too.
    Is there something in between, between the Simulator IN Values shown on the Simulator FlyPT Page (the Values do not change when switch to VR) and the IN Values for the motion parameter (the Values changes when switch to VR) settings in FlyPT?
    153,956Coins
    +11,160 / 57 / -2
    Just flagging this for @pmvcda, as I don't recall others reporting this with respect to FlyPT.
  3. gaco
    gaco New Member
    195Coins
    I did, thanks
  4. lysa elec
    lysa elec LYSA ELEC
    16Coins
    mf2020 is very instable in VR
    DCS is very good ans no problems
