Diy 2DOF motion simulator
Discussion in 'DIY Motion Simulator Projects' started by Adrian_since1986, Oct 1, 2022.
  1. Adrian_since1986
    Adrian_since1986 New Member
    Brazil
    - 109Coins
    Hello friends, I've been following the forum for some time, and this was the result of my prototype, made only with material I had at home, I wanted to test the electronic part and how the mechanical part would look, I really liked the result and the pleasure of having I was successful, for the final project I will use aluminum profile and 2 new motors (I imagine they won't have enough power) but that's what I had available for purchase at an acceptable price.
    Specifications:
    Voltage: 12V DC
    Speed: 30 RPM
    (rated): 5.5A
    (max.): 20A
    Torque (rated): 8Nm
    Torque (max.): 50Nm
    Weight: 1.7 kg
    Soon I'll post how the final assembly is, I'm still waiting for the motor mounts to arrive from the laser cut.
    Thank you for everything! :)
  2. Adrian_since1986
    Brazil
    - 109Coins
    Hi guys, updating the project
  3. Adrian_since1986
    Brazil
    - 109Coins
    This week a few more pieces arrive and you can already test the movement on the new platform
  4. Adrian_since1986
    Brazil
    - 109Coins
    Good morning guys, I received the hall angle sensors from China, and yesterday I went to test, I took the potentiometers that were working perfectly and turned on the sensors, but when I open the SMC3 the motors are off and the green line does not respond when I turn the sensor, I didn't find any information about it, but is there any different configuration to use the sensors? Thanks
    153,728Coins
    Check the Hall sensors are wired around the correct way.
  6. Adrian_since1986
    Brazil
    - 109Coins
    Thanks for the tip, but the connections were correct, I reduced the cable size by 40cm and it worked perfectly
  7. Adrian_since1986
    Brazil
    - 109Coins
    Good afternoon guys, first test of the current platform, it still needs some adjustments and I still understand the simtools, part of the lever stroke and the strength of the effects, but I'm very happy with the results Thanks
  8. HenriqueDourado
    HenriqueDourado New Member
    7Coins
    very nice your project
    I'm also wanting to build a 2dof like this, you have whatapp contact or email (whatapp preferred), I would love to talk to you
  9. Adrian_since1986
    Brazil
    - 109Coins
    Good morning everyone, moving on to update a little bit of the project, still making some adjustments but it's already possible to have a lot of fun :)
    My wife doing a test in the F1 22
