Question How to prevent 3DOF simulator to move in my room?
Discussion in 'DIY Motion Simulator Projects' started by David Vagenende, Oct 4, 2022.
Tags:
  1. David Vagenende
    David Vagenende New Member Gold Contributor
    - 31Coins
    3DOF, AC motor, Arduino
    Hi Simtools community,
    I have built a 3 DOF, Vesaro style, simulator. Very nice stuff, it does however move around to much in my room after a long stint with a lot of motion. So, I have to move it back in place every time. With a total rig weight of 75 Kg, it is quite annoying. What are your solutions to keep your motion simulators in place? (Without drilling holes in my floor? )
    Kind regards,
    David
  2. HI_iam_new
    HI_iam_new 0dof
    128Coins
    Do you have carpet or wood floors?
  3. David Vagenende
    - 31Coins
    Hi more like a linoleum floor.
  4. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
  5. HI_iam_new
    HI_iam_new 0dof
    128Coins
    I agree with the rubber mat suggestion.
    I also think that you'd benefit from adding another mat, of a different material, on top of that. I'm thinking that maybe a thicker, foam mat would be best for that purpose, so that the actuator legs can "sink" into it and achieve a better grip. You might also consider adding rubber feet to the actuator legs, if it doesn't already have them, to further improve its grip.
    I haven't tried this at all, so your mileage may vary. There is a potential drawback to using a thicker, foam mat on top though: the motion might feel less responsive, and you'll likely lose out on detailed feedback because the foam will absorb the initial movements of the actuators.
    It's probably best to only use the rubber mat first, with rubber feet on the actuators, and test to see if it meets your expectations.
  6. David Vagenende
    - 31Coins
    Thank you very much, I will try the rubber solution and keep you posted!
