Motor options Australia
Discussion in 'New users start here - FAQ' started by Paul Stargatt, Oct 11, 2022.
  1. Paul Stargatt
    Paul Stargatt New Member
    23Coins
    He there sim community folks, I am a ne member and just setting out on my 3DOF build. Fabrication and design are my stronger attributes, electrical... not so much.
    I am hoping to make contact with fellow Aussies for purchasing advice on some of the components. If anyone can help advise what electric motors I should purchase would be greatly appreciated. I am not sure what I need and want to avoid spending $$$ on the wrong item.
    Hoping to be racing you all really soon
    153,950Coins
    +11,160 / 57 / -2
    What motor specs you need depends on your rig design and desired performance, the likes of SimCalc can help you work out the tradeoffs between design Vs physics: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    We are lucky in Australia as we have Motion Dynamics. Depending on design needs they can supply 200w commercial motors: https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    Or a range of beefier industrial motors, in left or right orientations, coupled with your choice of wormdrive ratio: https://www.motiondynamics.com.au/320w-12v-24v-worm-drive-from-21-to-256-rpm-and-25-to-75nm.html
