F1 2022 v1.0
F1 2022 GamePlugin for SimTools
  1. GonzaloLastShadow
    GonzaloLastShadow New Member
    27Coins
    Hello. Now the plugin is not available for download.
    Is there a problem with the plugin?
    150,025Coins
    +10,993 / 54 / -2
  3. GonzaloLastShadow
    27Coins
  4. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Is udp 2022 still a problem, or is it solved ? I only get strange jumping signal both to game vibe and game engine. The signal is jumpy and looks like interference. Have to use 2018 to get signal. Latest simtools version.
  5. yobuddy
    50,036Coins
    This plugin automatically patches for, and is build around the 2018 output structure.
    Take care,
  6. Blekkulf
    Molde
    342Coins
    Thanks for clearing that :)
  7. Kenshiro27
    Kenshiro27 Active Member
    76Coins
    Hi first of all a big thank you for this plugin however it doesn't work for me yet all the other games yes but not F122 everything is connected but my motors just make very small jerks but no movement an idea please ?
  8. Blekkulf
    Molde
    342Coins
    Sounds like the udp problem discussed earlier. Both my motors and transducers are just shaking, and the values on tuning center are jumping. Try change the udp signal in the f1 22 telemetry menu from 2022 to 2018 or legacy.
  9. Kenshiro27
    76Coins
    yes that's what i did and it works fine
    thank you:thumbs
  10. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, still no news for simtools v3 thank you
  11. yobuddy
    50,036Coins
  12. bruno1210
    bruno1210 schumi06
    103Coins
    Thank you, I will test this v3 version tomorrow.
  13. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I am trying to make simhub and simtools work at the same time with the 2022 format but impossible to make it work only with the 2018 format, Shoe's method
    Let's Go doesn't work for me.
  14. yobuddy
    50,036Coins
  15. bruno1210
    bruno1210 schumi06
    103Coins
    yes works with 2018 format and not with 2022 format.
  16. Mu-KwangKim
    South, Korea
    - 689Coins
    I want to create a plug-in that supports UDP 2022 signals for SimTools V2.
    If possible, can I get the source code for the F1 2022 v1.0 plug-in?
  17. Mu-KwangKim
    South, Korea
    - 689Coins
    It is a video on how to use SimTools 2.5.5 and SimHub at same use in F1 2022 UDP 2018 Format.
    It's a temporary measure, but please refer to it!
    p.s. It's a Korean video, but there won't be much inconvenience! I'll add subtitles if necessary.
  18. Michail
    Michail Member Gold Contributor
    730Coins
    I make a time trail. than i patch the game, not working. than i make a ver quick session 3 rounds and remove the patch and patch again. still not working
  19. Michail
    730Coins
    I figured out it was 2022, when I change to 2018 it works. But without simhub. I have to look in the pages before from the corean guy's video hoe to setup both.
  20. yobuddy
    50,036Coins
