SimTools v3 Public Beta
  1. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the f1 22 plugin works very well too bad for the 2022 format.
  2. levers
    948Coins
    Hi Yobuddy,
    Thanks for your reply. I had another look at it this evening and it worked again for ACC but it seems inconsistent compared to V2.5. The volume sliders now work so I'm trying to set the levels again there as well as in the vibration setting parameters.
    I'll try DR2 again tomorrow and it's great news on the new features you are adding.
    All I need is an RF2 plugin now! :grin
  3. levers
    948Coins
    Hi Yobuddy,
    I think I might be going a bit mad. I played again with the vibration settings in ACC, you could spend weeks tweaking them!
    Tested it on F1 21 and it was fine and then on RF2 and that worked fine. I just need to optimise the min/max settings for both.
    I don't know what I did differently!
  4. yobuddy
    51,519Coins
    Update Pushed!
    Added - Start with Windows
    Added - Auto Detect a Launched Game
    Both options have been added to the options page. :thumbs
    • Winner Winner x 3
  5. ivan jack
    ivan jack Member
    412Coins
    Crashes every time I try to capture telemetry data from the game, unable to get motion running in game, but works in testing mode.
  6. yobuddy
    51,519Coins
    Can you click details on the crash and post a pic of the log?
    What game plugin is it?
    Have you tried with other game plugins?
    Thanks!
  7. levers
    948Coins
    Hi Yobuddy,
    I had to look closely to see the box colour had changed. The 'start with Windows' has been selected and it works fine.
    However, 'Auto detect' crashes Simtools when the games start.
  8. yobuddy
    51,519Coins
    Yes, skinning next so I'll get it fixed up.
    What game?
    Can you hit details on the crash prompt, and show me the log buddy?
  9. yobuddy
    51,519Coins
    Update Pushed!
    Fixed - Auto Detect Launched Games? o_O
    Added - .url file type support for setting a games launch shortcut (this is steams default shortcut file type) :thumbs
    Take care!
  10. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    @yobuddy
    Start with Windows :thumbs
    Auto detect crashes Simtools when the games start
    Asseto Corsa
    The log shows two errors.
    .NET Runtime
    - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2022-10-21T06:51:31.7062316Z" />
    <EventRecordID>58711</EventRecordID>
    <Correlation />
    <Execution ProcessID="0" ThreadID="0" />
    <Channel>Application</Channel>
    <Computer>DESKTOP-U1JBMLF</Computer>
    <Security />
    </System>
    - <EventData>
    <Data>Aplicación: SimTools.exe Versión de Framework: v4.0.30319 Descripción: el proceso terminó debido a una excepción no controlada. Información de la excepción: System.IO.DirectoryNotFoundException en System.IO.__Error.WinIOError(Int32, System.String) en System.IO.FileSystemEnumerableIterator`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].CommonInit() en System.IO.FileSystemEnumerableIterator`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]..ctor(System.String, System.String, System.String, System.IO.SearchOption, System.IO.SearchResultHandler`1<System.__Canon>, Boolean) en System.IO.Directory.GetFiles(System.String, System.String, System.IO.SearchOption) en SimTools.Cls_WatchProcess.Is_ProcessRunning(MyItem) en SimTools.Cls_WatchProcess.LookForAnythingRunning() en System.Threading.ThreadHelper.ThreadStart_Context(System.Object) en System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) en System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) en System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) en System.Threading.ThreadHelper.ThreadStart()</Data>
    </EventData>
    </Event>
    Application error:
    - <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2022-10-21T06:51:31.8358970Z" />
    <EventRecordID>58712</EventRecordID>
    <Correlation />
    <Security />
    </System>
    - <EventData>
    <Data>SimTools.exe</Data>
    <Data>3.0.0.0</Data>
    <Data>634d3079</Data>
    <Data>KERNELBASE.dll</Data>
    <Data>10.0.19041.2130</Data>
    <Data>3206f737</Data>
    <Data>e0434352</Data>
    <Data>0012df72</Data>
    <Data>3374</Data>
    <Data>01d8e5196cd358c4</Data>
    <Data>C:\Program Files (x86)\SimTools3\SimTools.exe</Data>
    <Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
    <Data>46f56fed-eba8-47af-8d34-041b566c7bbe</Data>
    <Data />
    <Data />
    </EventData>
    </Event>
  11. yobuddy
    51,519Coins
    @NjMotion,
    I believe the update I just posted above will fix it.
    Can you give it a shot?
  12. ivan jack
    ivan jack Member
    412Coins
    Simtools app just disappears from the screen and taskbar, no log saved. I tried Assetto Corsa and Dirt Rally so far. same thing happens for both. Another thing I noticed is some stutter in game when running V3 and I have a powerful PC, nothing like this happens with V2.
  13. yobuddy
    51,519Coins
    Could be related to the auto detect game launched bug, let me verify that's fixed.
    Let's get the auto bug fixed and take another look.
    The engine in v3 is way faster than v2, and it smooth as butter here.
    So let's get the auto bug verified fixed and we will try to figure out the capture Max / Min thing.
    Chat soon,
  14. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    @yobuddy
    I have updated, I have restarted the PC and SimTools3 keeps closing when starting Asseto Corsa and DirtRally2.0
  15. yobuddy
    51,519Coins
    Are you clicking the play button, or auto detect?
    Is auto detect games on?
    thanks!
  16. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    SimTools3 now closes in both ways, manual and auto detect.
    I'm going to reset everything and try again.
  17. yobuddy
    51,519Coins
    Thinking...
    Let me know what you find out please...
  18. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Auto detect, Simtools crashes.
    Play button, SimTools works fine.
  19. yobuddy
    51,519Coins
    Update Pushed!
    Fixed - Auto Detect Launched Games - I think... lol
  20. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Auto detect tested with Assetto Corsa and DirtRally2.0. It works perfect!
