SimTools v3 Public Beta
  1. yobuddy
    51,222Coins
    @gigi,
    Let me know what happens after the AMC interface update.
    Chat soon...
  2. yobuddy
    51,222Coins
    New game plugin loaded... :thumbs
  3. yobuddy
    51,222Coins
    Fixed - Kart Racing Pro Patching.
    (Know that depending on where the game gets installed, you may have to patch the game with SimTools launched as admin)
    Take care!
  4. yobuddy
    51,222Coins
    Update Pushed!
    Fixed - Indexing problem in GameDash (Display Selection)
    Fixed - GameDash screen now resets correctly when stopping SimTools
  5. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    all working as it should now thank you @yobuddy
    quick question if i may how far away are we from getting rf2 plugin?
  6. Mu-KwangKim
    South, Korea
    - 689Coins
    Um... OTL Unfortunately... not solve the problem.
    I checked this and that just in case there was a conflict with another program, but I couldn't find it.
    What's the problem? o_O:think:(
  7. yobuddy
    51,222Coins
    w00t!
    It's on the list for sure buddy.
  8. yobuddy
    51,222Coins
    Not sure, but the main form seems wider on your screen than it should be.
  9. levers
    955Coins
    Hi Yobuddy,
    I tried F1 22 today, it's on offer on Steam! The telemetry is a lot better than 2021 for some reason. I wanted to see what the VR is like and I have to say it looks really good. However, although V3 says the game is running there's no motion when using VR but there is in 2D mode. Just tried it in V2.5 and there's motion in VR. Not sure if it's just me?
  10. yobuddy
    51,222Coins
    Hmm... they patch the same way, thinking...
    Will you check "C:\Users\(user folder)\Documents\My Games\Grid Legends\hardwaresettings\hardware_settings_config_vr.xml"
    And take a peek to see if it looks like it patched.
    The only thing different I see is the port it uses.
  11. ivan jack
    ivan jack Member
    412Coins
    Tested AC , F1 22 , DRally 2.0 , everything works very smooth . No problems with max/min values or stuttering in game now. For those who want to use simtools v3 and simhub together with f1 22. use the F1 2018 tab from simhub. in game Game port 4122 forwarding to 4123 in simhub .
  12. levers
    955Coins
    Hi Yobuddy,
    I removed the F1 plugin and then reloaded it and it worked. I guess I needed to do a race in VR as well as in 2D before patching.
  13. yobuddy
    51,222Coins
    Awesome!
    You may know this already, but you can export a shortcut from steam to your desktop to launch directly in vr.
    And then drag drop the shortcut onto the F1 banner, and it will launch directly to vr from simtools.
    take care!
  14. ivan jack
    ivan jack Member
    412Coins
    a little bug lives in Grid Legends plugin. when I hit Pause in race, platform goes all the way to the left. I exit the game. Sim goes back to normal position. I pressed test motion and again all the way to the left. Closed simtools, opened again and test is working normally. If I enter the game again , hit pause, will do the same thing.
  15. levers
    955Coins
    No I didn't but I'll give it a try, thanks
  16. yobuddy
    51,222Coins
    What do your parking location settings look like buddy?
  17. ivan jack
    ivan jack Member
    412Coins
    They are all like in the picture. It happens only on Grid Legends.
  18. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    Is there a DUAL JRK plugin?
  19. yobuddy
    51,222Coins
    Yep, know that SimTools v3 will only auto re-setup 1 com port per interface. (setup plugin)
    So if you were to send someone a setup plugin, they would have to edit the settings for com port #2 by hand.
    Take care,
  20. yobuddy
    51,222Coins
    @ivan jack,
    I updated the Grid Legends plugin.
    Please let me know how it goes buddy.
