Showroom ODESC (Odrive) - BLDC - Linear Actuator (WYBO 200 / WYBO CONTROLLER)
Discussion in 'DIY Motion Simulator Projects' started by Will974, Sep 13, 2022.
  1. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
    Hello everybody,
    After having acquired a lot of experience during my first project, concerning the construction of a 6 dof simulator, I decided to relaunch myself in a new project.
    The link to the thread of my first project for information : https://www.xsimulator.net/community/threads/6-dof-odrive-bldc-new-design.14580/
    The purpose is now, to build a 4 dof simulator based on an aluminum Prosimu frame .
    The originality will be the linear actuators.... I name them: WYBO 200 :)
    I want to develop a new actuator based on an open SFX but fully different into it….
    Indeed, it will be a real pull/push actuator motorized by a custom Servo - brushless DC motor and high quality components...
    To finish the best : I’m going to use an ODESC as a controller & driver to pilot the motor. ;)
    And AMT 102V for encoder
    I will share more details during the evolution of the project. :thumbs
  2. Will974
    Reunion Island
    953Coins
  3. Will974
    Reunion Island
    953Coins
  4. clintonium-119
    clintonium-119 New Member
    - 18Coins
    Looking forward to seeing this come together. How do you anticipate the final cost will compare to the SFX actuators?
  5. Will974
    Reunion Island
    953Coins
    It's a good question that i wanted to answer since a long time. To answer your question, i make a table to compare only, the motor set between odrive solution and AMC solution... I don't want to discuss about this subject.... The conclusion is enough clear on the table i think.... Thanks :)
    Comparison -Odrive vs  AMC-one set.jpg 93870
  6. clintonium-119
    - 18Coins
    Thanks. I'm excited to see this project as it progresses. I'm building a DD wheel with an ODESC (have all the parts, just need the time to start working on it), and I was planning on a BLDC/ODESC motion rig next.
    Can't wait to see what you come up with :)
  7. Will974
    Reunion Island
    953Coins
    Thanks !!! I have also the project to build a ffb wheel with ODESC ... when i will finished the ODESC BLDC actuator.... I will add some news the next week ;-) Do you have a thread of your work ?
    • Old Old x 1
  8. clintonium-119
    - 18Coins
    Not yet, but once I get the actual build started, I'll be sure to post progress here.
  9. Thanos
    Electronics Engineer
    2,798Coins
    You forgot to mention that the AASD servos are available from small sizes and power (flange 60mm 400watt) to huge power and flange size (flange 130mm 5KW)...
    And don't forget the safeties included in these industrial servos, STALL protection, Over Torque protection, Overspeed protection, Automatic detection of faulty encoders or cabling, lower currents running through cabling compared to DC solutions... in short, everything to not worry if something catches fire!
  10. Will974
    Reunion Island
    953Coins
    Hi thanos,
    As i said, on another thread, this table is an answer of peope who asked me the difference price between the two solution. So i make a comparison with the price criteria only.... As i said, the amc solution is easiest than odrive solution. I don't want to discuss about who is the best..... Both solutions deserve to exist ;-)
    Another thing, you know that it's not adviced to build a rig with a 60ST ac motor because , torque is too low.....That's why , 100 % people use 90 ST or 80 ST motor....
    In odrive firmware that i use, there's also several security about speed, current , torque etc.....
    I repeat, there's no competition.....Both solutions deserve to exist....People make their choice ;-)
  11. Thanos
    2,798Coins
    Sure. But another item not included in the cost math in that table, the high quality shielded wiring for the servomotor power and encoders that is included in the servo drive and servomotors kits.
    In DIY BLDC, you could spend lots of money and time having to gather the really thick AWG wiring, manufacture your own cables, add shielding, and also build the shielded wiring for the encoder.
    It's very easy for someone without experience in making such wiring, to make mistakes that can cause problems, happened to me even with experience in the matter. I try to use systems where you don't need to make any wiring or cables, and use what is available off the shelve, already build!
    Again, pointing out what really matters, not competing, and that users should educate for themselves before take on something because its a few $ cheaper. Almost every time there's a catch.
  12. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    i have the same odesc board but i cant configure the board because i have minimal experience about this board...
    odrive based board not as easy as vesc based....
    and its not intuitive at all because it doesnt have UI like vesc, but it still have very big potential if someone can build using odrive based board...
  13. Will974
    Reunion Island
    953Coins
    VESC is used to control motor speed. With ODESC or Odrive, we use it in control position mode. There's several tutorial on youtube that show you, how to set it easily...
    Odrive have official GUI and others non official GUI. I invite you to make some search on odrive forum community ;-)
    Good work :thumbs
  14. Will974
    Reunion Island
    953Coins
    Work is progressing....
    The actuator is fully designed ....
    Stroke is : 200 mm (+ 20 mm security stroke)
    The actuator uses a custom sevo brushless motor with integrated fan :)
    The actuator can be used in real push/pull mode with u-joint on each side if needed.
    If needed for fun , the actuator can work without motor cover ( but it's not secured to do that :) )
    It's time to print the different parts in PETG ....
  15. Will974
    Reunion Island
    953Coins
    There' s some news about the development of the actuator. I made some improvements as you can see on photos.... The fan is now a separate module that you can add in option. Power cable and encoder cable is now securised by a cover... To finish, i added a plate to secure the access of the coupling.
    It gives a nice actuator :) Evo 1.jpg Evo 3.jpg
  16. Will974
    Reunion Island
    953Coins
    About the ODESC, i made a test bench to develop and set correctly the board.... The final will be a good surprise !!! It's for soon :thumbs 20230524_123051.jpg
    And the real :o:
  17. Will974
    Reunion Island
    953Coins
    The first real actuator looks very cool !!! hug:
  18. clintonium-119
    - 18Coins
    Thanks for the update. Excited to see how it performs for you.
  19. Dan82
    Dan82 New Member
    Pilot
    NRW, Germany
    51Coins
    Hey Will,
    thanks for the great work on this project. Very very sexy.
    Could you tell us your experience with this actuator in the past months and what, if anything, you would do differently a second time around?
    Would you be so kind to post a little parts list? Which aluminum profile (100x100 or 80x80? Length?), which ball screw (width/length/lead), which hollow shaft?
    Thank you so much.
  20. Will974
    Reunion Island
    953Coins
    The actuator is working perfectly and have a strong conception. I have designed a second version with some improvement .... About the control, i'm working on a solution specifically for odrive. It will be a new post.
    For now, i can't share the design but certainly in a near future on a website that i will share the link. Some details:
    Aluminum profile : 80x80
    ballscrew 1605 with a specifical nut
    Hollow shaft: Outer diameter : 30 mm
    I use mostly standard part that can be find on aliexpress as sfx...
    Other dimensions are depending to your design....
    Good work ;-)
