Showroom Motorcycle 4 DoF Motion sim
Discussion in 'DIY Motion Simulator Projects' started by Chris_Beeves, Sep 10, 2021.
  1. Gadget999
    12,001Coins
  2. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    400Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Good afternoon! I enjoy following your project.
    My assembly https://www.xsimulator.net/community/threads/mobile-platform-tl-catopult.17175/, in terms of the arrangement of motors, is somewhat similar to yours, and there is also a problem with the load on the motors. It will not be difficult for you to tell in more detail about "M-struts" (how are they arranged and where did you order them?)
  3. Chris_Beeves
    2,076Coins
    Fixing the front meant that the struggle in the rear became more noticeable. So I bought another strut!
    The struts are called LMS2815230 and are pretty much springs in a tube.
    Mine are something like 420N per spring fully compressed.
  4. Chris_Beeves
    2,076Coins
    I ordered them from fjadrar.se , a danish company.
  5. Chris_Beeves
    2,076Coins
    I upgraded the force feedback from the buggy stm esc1 to Roman’s odrive FW the other day, and it really lifts the experience! The steering is not what I want it to be still, but I really enjoy feeling the front tire again! It works extremely well.
    Also, I entered a championship to get myself on the bike more. It has given me a lot of hours of testing which I wouldn’t have done otherwise. I’m really feeling like I’m getting somewhere with the motion profile.
    Finding compromises that work for a motorcycle in VR is not easy. The littlest detail can really mess with the VR legs, but I have had a lot of progress the last few days.
    And the ‘knee-down-rumblers’ are finally back in business! I love them, but they need some kind of mechanism so they only work when you actually put your leg out.
  6. Chris_Beeves
    2,076Coins
    Had a friend over the other day to try out the rig. His reaction to the full VR experience was great!
    However the current gear shifting mechanism, which is a carryover from one of my earliest projects that has survived unexpectedly long failed in turn one. So I finally took the time to test one of my ideas. The linkage still needs to be sorted.
    I also took the time to write make a lite motor temp monitor system. The problem has been pretty much solved with the springs, but I thought it would be nice.
    It shows the current temperatures and the measured maximum.
  7. Gadget999
    12,001Coins
    does the temp recorder use themisters ?
  8. Chris_Beeves
    2,076Coins
    It has DS18B20 sensors.
  9. biyajie00638
    biyajie00638 New Member
    6Coins
    I want to make a 2dof motorcycle simulator, is it possible?
  10. Chris_Beeves
    2,076Coins
    Yes, go for it
  11. Chris_Beeves
    2,076Coins
    The gear switch thing worked great! The wiring side could have been a bit more tidy though, and the mounting was a pain. The coolest part was the print-as-one ball joint for the gear lever. Fun!
    Now I am working on a new steering concept which will have to do as a compromise until PiBoSo gets the directsteer function working again on GPbikes.
  12. Chris_Beeves
    2,076Coins
    Shot a short video of the rig in motion. Nothing fancy, but gives you an idea.
    The leaning, or lack of it and why leaning the right way is wrong, I'll try to explain in another video.. ;)
  13. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    I just wonder what if these rigid links are replaced with air springs.
  14. Chris_Beeves
    2,076Coins
    Why would you want to do that?
  15. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    So that you can lean the sim with your weight and at the same time feel the motion feedback from the motors.
  16. Chris_Beeves
    2,076Coins
    Lean is not an input, it’s an output. It is the product of handlebar and weight transfer inputs.
  17. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    Owh... sorry. I always though it's the rider that has to lean the motorcycle to counterbalance centrifugal & gyroscopic forces (sway as in simtools output).
  18. Chris_Beeves
    2,076Coins
    Working on torque sensing handlebars to explore making a more natural steering system.
    As it is now I can choose between;
    • Steer left to go left
      - Completely unnatural to me, and a dangerous reflex to learn
    • Steer right to go left
      - When initiating a turn it feels quite nice and the force feedback gives a nice feel, but continuously steering the ‘wrong’ way in a turn just isn’t right..
    • Directsteer
      - PiBoSo’s hardcore steering mode with all aids off and 1:1 ffb control of the handlebar angle was what made me try the game from the beginning, but the code just isn’t good enough as it is right now, making it extremely extra difficult
    • Torque steer
      - The new concept of emulating countersteering with some semi clever arduino coding. First test are promising, but there’s still a long way to go.
    How would you guys want a bike sim to steer? (Don’t say by leaning it ;) )
  19. Chris_Beeves
    2,076Coins
    There is of course the “swivel type” steering like iasystems use on their HS controllers. It’s probably the best option for something like an arcade machine since most people can relate to the lean type control and learn how to use it quite quickly.
  20. Gadget999
    12,001Coins
    does your sim not lean ?
    can you put load cells under the actuators or handlebars and measure the weight transfer left to right ?
