Brake pressure sensor
Discussion in 'DIY peripherals' started by jakob, Nov 10, 2009.
  1. jakob
    jakob New Member
    Frankfurt
    313Coins
    I just found (conrad.de) that pressure sensor:
    It costs around 12€, has a durability of 10.000.000 operations and works like a pot with 1V-5V.
    Should work fine in combination with a progressive elastomere gum, so the pedal can move a bit and the sensor won't get hurt by blank metal.
    German data sheet: http://www2.produktinfo.conrad.com/date ... _150NS.pdf
    Anyone tried one of these?
    Cheers,
    Jay
  2. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    I have one, i only tri it with gameport (long time ago) and multimeter. It need op. amplifier to get linear progression.
  3. jakob
    jakob New Member
    Frankfurt
    313Coins
    The sensor has 15kΩ@1Nm/100g and 3kΩ@100Nm/10kg. Should be enough for the software. I'll give it a try :)
  4. Alviomsim
    Alviomsim New Member
    Electronic Assembler
    USA
    344Coins
    hi jakob Where you found that?..i cannot find that in this conrad. de everything is in German..you know about in English store .i appreciate more information about the store...my best regards
  5. jakob
    jakob New Member
    Frankfurt
    313Coins
  6. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    But look at graf, its behave like you little push and its go from 1000kOhm to 10kOhm instantely, then there is small area where you can use it and then its almost insensitive. I was able to stear with it by putting PET bottle to it an push thru it (i can contrl force mutch better. In datasheet they have circuit with Op. amplifier to get linear proggresion. zapojeni.jpg
  7. jakob
    jakob New Member
    Frankfurt
    313Coins
    Oh, thanks.
  8. Alviomsim
    USA
    344Coins
    Thank you very much jakob now i can complete my F16 stick Transducer :clap:
  9. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I'm using a load cell/strain guague for my brake. A simple interface circuit with an INA122PA chip gives 0-5v output for Mjoy etc. It's the same chip Leo uses in his LC USB joystick interface. Chip is < AU$10, load cell can be had off ebay for about AU$25. Check my site for PCB and circuit layout.
  10. willynovi
    willynovi Member
    Argentina
    354Coins
    I also use INA122P with a load cell, I think it´s the best solution.
  11. jakob
    jakob New Member
    Frankfurt
    313Coins
    I've found a way to get rid of the amplifier. Very easy to build with a tiny 8 legged uC and a low pass filter. Can be hooked up to any joystick controller.
  12. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Sounds interesting! Could you make a layout for this circuit as soon as it is tested?
    Regards
  13. jakob
    jakob New Member
    Frankfurt
    313Coins
    Sure. The layout and code are already done. Couldn't test it because I fried the last pressure sensor. Bought a couple new sensors (7$/piece). But shipping from overseas takes some time...
  14. willynovi
    willynovi Member
    Argentina
    354Coins
    could you give the specification of that component, here is very dificult to find INA122P.
  15. Frakk
    Frakk Active Member
    328Coins
    There are some semiconductor based pressure sensors around for a reasonable price and they already have calibrated and amplified outputs. I'll try to find some specific parts.
