Best Way to Attach Shaft to Motion Dynamics Motor?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by PMK, Feb 21, 2020.
  1. PMK
    PMK Member
    Australia
    125Coins
  2. MarkusB
    4,215Coins
    Exactly as you described: I used 1/2'' threaded rod (which was not so easy to get in 'metric Germany'). Then I drilled a 4mm hole into the rod and in this way connected it to the hollow shaft with a 4mm bolt. In addition, I fixed the rod on both sides with a nut.
  3. Zed
    USA
    5,845Coins
    I used clamping with a roll pin. It’s been rock solid.
    2AAE2FB0-F143-403B-896F-ECFF1EF306F0.jpeg AEB2E14B-73ED-43C0-B99D-FE4BA37E2D3D.jpeg C811FDCB-233E-4063-A283-02D9301148B9.jpeg
  4. dieser
    dieser Member
    372Coins
    looks very solid.
    is it selfmade?
  5. Zed
    USA
    5,845Coins
    Self-designed with one caveat and I have a machinist friend who cut it for me. He also made a really good suggestion and modification to the design. Instead of the clamping clearance being all the way from shaft to clamping end, he left a bit right at the edge. Otherwise they are to drawing.
    He said that without that bit, the clamping bolt would bend the clamping arms and weaken the clamping action. By leaving that little bit, the bolt tensions and clamps the other way - at the shaft. If I was doing it again, I'd extend the clamping arms out a little further to give the clamping bolt more leverage but these are great with zero loosening as they are. Extending may not be necessary. BTW, the guy is an amazing machinist. His work is art.
    The zip file has my original .stl file seen in the render.
    And I realized just now the OP was asking about attaching a shaft - not an arm.
  6. ivan jack
    ivan jack Member
    412Coins
    Hello, I know this is an old thread , but maybe you can help me with this. Were you able to open gearbox and change motor shaft from one side to the other to mount them mirrored? Thank you!
  7. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    Thank you Zed, I could use that drawing soon
    153,740Coins
    Yes you can do that with these.
  9. Zed
    USA
    5,845Coins
    I think I was. On my system I have both motors oriented the same and had to flip one output gear to get them to be the same logically. Caveat, though. It’s been a long time since I did that. I remember opening the gearbox for certain, but I may also have just logically swapped one. But I think I did flip one. Sorry I don’t remember that bit exactly.
  10. Zed
    USA
    5,845Coins
    The stl of my output arms was posted just a couple of posts above yours. Is that not what you were looking for?
