Microsoft announces new flight simulator 2020
Discussion in 'Flight Simulator 2020 - FS2020' started by noorbeast, Jun 10, 2019.
  1. noorbeast
    153,950Coins
    +11,160 / 57 / -2
  2. MarkusB
    4,215Coins
  3. Zed
    USA
    5,845Coins
  4. MarkusB
    4,215Coins
  5. MarkusB
    4,215Coins
    Update: It's available. Go and get it before it is sold out. :)
  6. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Is anyone playing fs2020 with windows mixed reality? Im just curious if anyone has had any luck with reprojection. Some people claim it is buttery smooth at 22.5 fps. My main issue is when I turn my head the headset doesn't seem to keep up.
    Im running rtx3070 with 3700x processor.
    153,950Coins
    +11,160 / 57 / -2
    Have you tried turning down graphics settings, if so what do you have them set at?
  8. Keith
    Keith Active Member
    Electrician
    154Coins
    I tried turning the graphics down almost all the way last night. It was still a jerky mess. I then turned reprojection off and it plays much smoother. I think I will call it good enough for now and get back to flying.
    Thanks for the help!
  9. PEB
    PEB New Member Gold Contributor
    - 78Coins
    4DOF
    Just tried it for the first time last night very good but for some reason my cheap flight stick only works but cannot see any action in the helicopter. The other I installed the helicopter and did not see it till the newest update.
  10. MarkusB
    4,215Coins
    I did not try this helicopter by myself, but only the one I mentioned in this post.
    With this Bell 47, I initially had the problem that my controllers did not work correctly. For example, I saw the helicopter's rudder pedals move when I pushed my controller pedals, but the helicopter did not react accordingly by turning left/right.
    The reason was that I had some of the flight model simplifications enabled within MSFS. After disabling them, all helicopter controls worked as expected. Not sure though if the source of your problem is similar.
  11. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    Since a recent update which corrected the acceleration bug, we are finally able to profile a coherent classical washout algorithm for 6-dof rigs.
    Here a simple starting point quickly tuned for FS2020 Zlin Shock Ultra and some settings for VR with virtual tracker for MC (G2 headset with internal tracking) and rendering optimisations.
    You can also save about 30s. launch time by creating an extra shortcut explained here:
    https://www.reddit.com/r/MicrosoftF...c/psa_to_skip_the_intro_videos_and_logos_set/
    IMPORTANT: Don't forget to adapt the rig geometry and range to your design.
    Big hug to @pmvcda
    • Like Like x 5
  12. SeatTime
    Half way through downloading update 5, hopefully this will let me run in the 8KX at a good quality and frame rate :think.
  13. noorbeast
    153,950Coins
    +11,160 / 57 / -2
    I am up in the Sunshine State for the next week and a half, so let us know how the post update performance is.
  14. lysa elec
    lysa elec LYSA ELEC
    16Coins
    big problemes with flight sim 2020
    no code of validation so tribunal
    153,950Coins
    +11,160 / 57 / -2
    Sorry I don't know what you mean by '
    no code of validation', can you please be more specific and include pictures of the issue
  16. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    Have you checked in the spam folder of your email client?
    Sometimes emails from reliable senders are labeled as spam even if they are obviously fine.
  17. nils8107
    nils8107 New Member
    21Coins
  18. noorbeast
    153,950Coins
    +11,160 / 57 / -2
