Homemade 3DOF simulator the beginning of the project
Discussion in 'DIY Motion Simulator Projects' started by radist07, Nov 3, 2022.
  1. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I have been preparing to start building this project for a long time. At the beginning, I installed the Microsoft Flight Simulator 2020 and learned how to fly a plane a little, I realized that I needed a more natural immersion in the reality of flight. After studying the work of other people, I realized that you can try your hand. First I bought 3 motors from car wipers, installed them on metal plates. I connected the feedback resistors to the motors using gears made on a 3D printer.
  2. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I want to supply power supplies from the server 12 volts 850 W
  3. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Now I'm building an arduino and motor control drivers
  4. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Assembled the scheme
  5. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    nstalled additional cooling radiators. It is necessary to put an insulator gasket between the radiator and the board,
  6. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I set up the electronics according to the video lesson Thanks to the author for a detailed story!
  7. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Making a platform from materials I found in the garage
  8. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Profile pipe. It was heavy, but I had it
  9. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    A seat from a Japanese car
  10. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    It remains to be treated from rust and painted
  11. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    partial installation
  12. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Assembled the mechanical part. I assume that the motors will need to be installed at the back of the chair because there the lever relative to the hinge is longer and it will be easier for them to move. but first I'll try in this version
  13. noorbeast
    151,979Coins
    +11,061 / 56 / -2
    I think you may be right as the wiper motors may not have enough design leverage to drive the rig mass when loaded.
  14. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    Hi, it looks like you are giving birth to a nice rig.
    I'm currently designing mine, I am interested in following your build.
    Have you already decided what software will connect the game to the motors?
  15. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Hello, software SimTools + arduino+ BT-2
  16. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Today I tested the installation. As expected, the motors turned out to be very weak, they worked only at peak modes, fine motor skills were not felt (((. I will put 250W 24V from the kalyaski
  17. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    Hi radist07, thanks for the reply.
    I ordered two wheelchair motors 250W 24V 75rpm from China
    I googled kalyaski but couldn't find anything related to motors, is that a shop?
  18. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
  19. fabrizio1203
    fabrizio1203 Member
    - 7Coins
  20. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
