3dof---jazzy wheelchair motors---flight sim version
Discussion in 'DIY Motion Simulator Projects' started by stanley johnson, Oct 14, 2022.
  1. noorbeast
    151,668Coins
    +11,045 / 56 / -2
    Around that, or a little less, as best be conservative and work out from there.
  2. stanley johnson
    stanley johnson Active Member
    Diesel tech
    Nashville
    82Coins
    That
    Thats going to put my push rod at an angle is that ok or I need to move the motors so the the push rod is straight up and down?
    151,668Coins
    +11,045 / 56 / -2
    Ideally the push rods should be as close to right angles with the levers when the platform is at rest, for now work out what CTC works well for your rig then move the motors once that is known.
  4. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Willl do, thanks for your input
  5. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Using an old dell computer case to house these goodies 8A6481F3-F379-4649-9C6B-0BEE86626A88.jpeg 98175717-38FA-44DC-8F85-DF336D534ED7.jpeg 7BE849AA-4667-4545-95BF-199906C42A17.jpeg
  6. stanley johnson
    Diesel tech
    Nashville
    82Coins
    All wired up
  7. stanley johnson
    Diesel tech
    Nashville
    82Coins
  8. stanley johnson
    Diesel tech
    Nashville
    82Coins
    I forgot to mention about the spot in the middle of the computer screen, thinking the screen is burnt just ignore it
    151,668Coins
    +11,045 / 56 / -2
    The
    The pots need to be centered when attached to the motors, and SMC3 properly configured.
    Have you followed the Initial Setup steps in the SMC3 instructions: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Initial Setup
    I strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    8. Set Kp to about 400
  10. stanley johnson
    Diesel tech
    Nashville
    82Coins
    image.jpg even with everything at 0, the motor still jerk when powered up
    151,668Coins
    +11,045 / 56 / -2
    Fpwm should likely be 25, ensure the pots are centered (motor off check track line in SMC3) and the pot brackets don't flex. Step - set to 1.
  12. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Is there a mark on pot to let me know they are centered?
  13. stanley johnson
    Diesel tech
    Nashville
    82Coins
    What’s track line?
  14. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Is track lines the lines on the smc3 graph?sorry I’m still learning
  15. stanley johnson
    Diesel tech
    Nashville
    82Coins
  16. noorbeast
    151,668Coins
    +11,045 / 56 / -2
    I
    In the Display settings of SMC3 (left side of UI) you can temporarily turn everything off except the line tracking the pot, to ensure the line, and hence pot, is centered in the graph when the pot is attached to the motor.
  17. stanley johnson
    Diesel tech
    Nashville
    82Coins
    It’s either high or low, it will not go to center
  18. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Rotated it to the left and it moved to center, do this mean my pot is centered?
  19. stanley johnson
    Diesel tech
    Nashville
    82Coins
    But what I noticed is the motor in top left turns off , is that normal? All three showing off
    151,668Coins
    +11,045 / 56 / -2
    Just checking, is the pot perhaps 180 degrees out of rotation?
