Question WRC Generations
Discussion in 'News' started by Ochso, Nov 8, 2022.
  1. Ochso
    Ochso New Member Gold Contributor
    CAD Designer
    - 60Coins
    3DOF, SCN6, Motion platform
    Firstly , appologies for asking, as you guys are no doubt busy coding Simtools 3.0
    But (and there is always a but) it appears that WRC Generations now has native telemetric data output .
    The only version to do so afaik . ( not counting the 'DR2.0 hook hack')
    This does of course lead to the somewhat obvious question of " Will there be a plugin / is there a plugin on the cards for it for Simtools 2.5 ?"
    Again apologies for asking.
    Many thanks
    Ochso
    Edit : If I have placed this in the wrong place please move
    153,950Coins
    +11,160 / 57 / -2
    While there is always the possibility of any member deciding to create a new SimTools v2 plugin, as the information is available to do so, it is hard to imagine why someone would be willing to expend the time and effort when SimTools v3 is in open Beta testing, and has a different plugin framework.
  3. Ochso
    CAD Designer
    - 60Coins
    Ah thought as much .
    (Cheers for the links btw - I may well "have a go" if time permits)
    Thank you for the speedy reply
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    I see simhub is supporting WRC Gen with no work around just udp which is awesome news :thumbs
  5. SeatTime
    FI, SRS also has support.
  6. Manuelx83
    Manuelx83 New Member
    - 164Coins
    hello.. sorry.. I would like to know if the wrc generation plugin will be implemented thanks
    153,950Coins
    +11,160 / 57 / -2
    Please see my earlier comment:
    The API and guide for SimTools v3 has not yet been done but according to the dev team is a high priority.
    In the mean time, there is always the Generic Joystick plugin for those who want motion in a game that does not yet have a dedicated plugin: https://www.xsimulator.net/communit...otion-plugin-and-vjoy-controller-mapping.387/
  8. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I’m using a “fake” dirt rally 2 exe so it looks like the game is running.
    Sim tools thinks dr2 is running and motion for wrcg works without any changes at all. It’s exactly the same as dr2.
    Is it possible to just do a copy of dr2 plugin and only change so it recognizes wrcg.exe instead of dirtrally2.exe. Sounds very easy but I don’t know how to edit a plugin.
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    There's no need for this fake hacking with WRC Gen it has full telemetry support just need a real plugin made im sure in time someone will do one :thumbs
  10. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    Of course I know wrcg has telemetry. That’s why I’m using this dr2 fake exe to get motion working until there is a plugin. I’m just saying it seems to be so easy to fix for someone who can create plugins. Just a duplicate of dr2 plugin as everything is the same.
  11. yobuddy
    51,547Coins
    @Hamreus
    I can try to roll a plugin, but I need to know the process name for WRC Generations?
    (So SimTools can detect it, it's usually the exe name, but not always.)
    I think its "WCRG.exe"?
    And can you show me the file found at:
    "C:\Users\(user name)\Documents\My Games\WRCG\UserSetting.cfg"
    So I can fix the patching for the game.
    Thanks!
  12. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    Yes it is WRCG.exe and here is the user settings file...
  13. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    Thanks @yobuddy
    The WRCG plugin for Simhub is now working
  14. Oliver Wallner
    Oliver Wallner New Member Gold Contributor
    - 133Coins
    Hi everyone, I also just tried to install WRC Generations plugin in Sim Tools 3 yesterday. When patching, I had the impression that the config file was not updated for Sim Tools 3 at all. I don't have too much experience with Sim Tools, but if I understand correctly, the game has to be started for the config file to be updated by Sim Tools. But this doesn't seem to be happening.
    @yobuddy,
    is there any hope that there will be a plugin? I love rally and this WRC is by far the best part so far. I have an elaborate simulator that I could use to test all of the effects as well to see if they work correctly (and I'd love to do that). So if there is any news on the plugin that it might work I'd really appreciate a message here. I would be happy to check all the functions for the motion. Greetings fuzimumpl
  15. yobuddy
    51,547Coins
    The game should not be running while you install the plugin.
    Roll and pitch output seem not quite right but the plugin is confirmed working.
    Take care!
  16. Claudioprogaimer
    Claudioprogaimer New Member
    124Coins
    Hi, friend. Can you tell me how to do it with fake dirt 2 so that the wrc generation works? Thank you very much if you tell me or give me a link to a tutorial.
    153,950Coins
    +11,160 / 57 / -2
    Please see the earlier post:
  18. marcelo m grama
    marcelo m grama New Member
    7Coins
    Hello everyone.
    When I try to install the wrc generation plugins in the sim tools in the steam folder, it says "the selected path is no valid for patching" any help? Thank you so much
  19. Oliver Wallner
    - 133Coins
    I have the same problem. Which folder exactly must be specified here in Simtools 3 in order to install the WRC Generations plugin. IT DOESN'T WORK! I get the same error message "the selected path is no valid for patching.
    A “game save path” simply does not exist. The installation folder doesn't work either. The folder on drive C where the settings are stored doesn't work either. Always the same error message.
    153,950Coins
    +11,160 / 57 / -2
    I don't own it so am only guessing, but have you tried: C:\Users\(user name)\Documents\My Games\WRCG\
