FlyPt Mover 6DOF DIY Projekt
Discussion in 'DIY Motion Simulator Projects' started by Dietmar, Nov 5, 2022.
  1. Dietmar
    Dietmar New Member
    230Coins
    3DOF, Arduino
    can anyone give me a recommendation for a useful rig setting for my setup. None of the choices in FlyPT really fits my setup. Maybe I can use the 6DOF marked in the picture, but I'm not sure how it works with axis 7 in my setup.
    Regards and thanks in advance
    Leines
  2. Historiker
    9,208Coins
    Hi @Dietmar your rig is very similar to mine. Try using the PT Actuator profile as a base.
    EDIT: Sorry about that, I clicked post reply before actually finishing my thought....old age I guess. (Dagnabit! I did that twice! I meant to click advanced and clicked save changes.....[the author got lost in incoherent mumbling for a while here])
    Anyway, you can start with the profile that you have and edit it for your functions. That is what I did before a Thanos PT Actuator profile was added.
    For example I used use the four corner, 4 DoF with TL + 3DoF (4 linear actuators) and then add more rigs for the other motors. You just have to move where the motors are and what their angles/ranges are. Specifically I used the 1DoF with single linear actuator, etc.
    But I do think they one that you are using can be edited for your use.
  3. Dietmar
    Dietmar New Member
    230Coins
    3DOF, Arduino
    Thank you for the answer. That sounds good, I'll give it a try.
    BR Leines
