Bug Assetto corsa competizione plugin crashed simtools
Discussion in 'SimTools DIY Version' started by Tino.Sturlic, Nov 28, 2022.
  1. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    199Coins
    I installed ACC plugin with plugin updater and now game menager and game engine wont start at all.
    What is happening, what can I do? Can I somehow uninstall the plugin, reverse this? Nothing works now.
    This is the error.
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameManager.frm_GameManager.LoadGameList()
    at SimTools_GameManager.frm_GameManager.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at SimTools_GameManager.frm_GameManager.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.5.1
    Win32 Version: 0.2.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4536.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.4579.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
    Win32 Version: 4.8.4435.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AssettoCorsaCompetizione_GamePlugin
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Users/tinos/AppData/Local/SimTools/GamePlugins/26_GamePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    153,986Coins
    +11,162 / 57 / -2
  3. yobuddy
    51,555Coins
    Delete the plugin from, "C:\Users\(user name)\AppData\Local\SimTools\GamePlugins".
    Looks like it's 26_GamePlugin.dll, please note that this is a v3 plugin and not a v2 plugin.
    As V2 plugins are only for v2, and v3 plugins are only for v3.
    Take care!
  4. Tino.Sturlic
    199Coins
    Deleting the "AssettoCorsaCompetizione_GamePlugin.dll" plugin did not change anything.
    Same message even after windows restart. I deleted "26_GamePlugin.dll" now game menager and game engine starts normally (motion works in output testing) but not in game.
    What is the best course of action now?
    And while we are at it, can you please provide a link for V2 plugins? Your page is a bit puzzling and I can only find the link for V3 plugins.
  5. Tino.Sturlic
    199Coins
    UPDATE:
    It works fine now. In the process I deleted Assetto Corsa plugin also, so it didn't work in asetto.
    Returned the Assetto corsa plugin from my backup file.
    A link for the Assetto Corsa competizione V2 plugin download would be much appreciated. :)
    Thank you for the help.
    153,986Coins
    +11,162 / 57 / -2
    All SimTools v2 plugins are here: https://www.xsimulator.net/community/marketplace/
    Including Assetto Corsa Competizione: https://www.xsimulator.net/community/marketplace/assetto-corsa-competizione-plugin.220/
