DIY H-Shifter by Willynovi - Working
Discussion in 'DIY peripherals' started by willynovi, Mar 15, 2010.
  1. akina
    akina New Member
    1Coins
    Re: DIY H-Shifter by Willynovi - WIP
    @ Willynovi : It is a splendid realisation :hi:
  2. Frakk
    Frakk Active Member
    328Coins
    This way you can map gears to different configurations. If you look around for real shifters you will see that the Reverse gear is some cars in the top right position, in some it is on the left and so on. With an 8 position shifter you can have up to 7 speeds + reverse in any configuration.
  3. Mambo
    Mambo New Member
    Czech Republic
    288Coins
  4. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    6+r for me is plenty. Most cars with 6 or more are sequencial anyway. an 8 position shifter would get pretty hard if you want to skip gears as it would not center on a gear like most street cars do. Maybe it would just take some getting used to though...
  5. willynovi
    willynovi Member
    Argentina
    354Coins
    as Frakk said, I can map any form of the H patern.
    Yes, maybe with 5 + R is enough, yesterday I made some test and it work as I want, I need to make some adjust in switches position but it will take me no mor than 10 minutes.
  6. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I understand what you mean but then the shifter will center between the gears, not inline with 3/4 like a traditional shifter (unless you have some metod of sliding the base of the shifter over?)
  7. willynovi
    willynovi Member
    Argentina
    354Coins
    some progres, it´s working :rofl:
    Please don´t laugh at my racing style :D
    http://www.youtube.com/watch?v=o3KSEHieh6Y&feature=player_embedded
  8. pdor90
    pdor90 New Member
    0Coins
    elnino or willynovi let me know if you have a drawing of your changes because I want to make it similar to yours. I had one ever built by me but has not done a good job and has many games as your seems well made and solid.
    thank you
  9. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I have an autocad 3d drawing as per my avatar if you would like it....
  10. pdor90
    pdor90 New Member
    0Coins
    :) thank you if you'd be happy to pass it. Yesterday I started doing it and I miss 2 / 3 special that I still do.
    but I did not understand a thing as it does to your self-center?
    Thank you for availability.
    I apologize for my English I'm 'using google translator. :hi: :hi:
  11. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Yes, the English is a little off but understandable.
    The spring that is at the top is trying to push the whole shaft assembly up through the rod end. Because the teflon block at the bottom is flat and secured to the shaft, it wants to hold center. I can take some video of it in close action if you like. Basically, as you push it to the side, the shaft is pulled down against the spring so it wants to pull back.
    The file is an Autocad 2009 3d drawing. You should be able to open it with Autocad Design Review (helps with measurements etc) or TrueView (view only) tool - Go to autocad.com and there is a link to them in the bottom right.
    • Optimistic Optimistic x 1
  12. pdor90
    pdor90 New Member
    0Coins
    Your design is very nice :thbup: , but I have a small problem with the joint that moves the rod.
    I took a plastic joint with a hole 8 mm. you take photos or videos at the joint in motion? :) . to understand how they work your pieces.
    here is a picture of my hub:
    here is the model made by inventor on PC (I have yet to complete):
    Thank you for your patience and willingness.
  13. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Here are some commented closer pics. I am not so sure your 8mm rod end will work too well as the surface area might be too small. Either that or you will need to counter it with a stronger spring at the top.
    Note the position of the yellow line across the shaft - It moves down pulling against the spring.
    Also note that the only things secured to the shaft are the shift knob, top collet and bottom collet - no other part is secured to the shaft at all. It is all free moving.
    The cad drawing is slightly different where it leaves out the bottom collet and the teflon is secured to the shaft. Minor difference but functionally the same.
  14. legreg
    legreg New Member
    0Coins
    Elnino,
    Is it possible to have the measure of each piece of your H shifter? I have your shifter 3D draw but it's not the good scale in my dwg viewer.
    Other question, have you make each piece yourself or a professionnal did it for you?
  15. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    What measurements do you need? I posted some dimensions in a pic back on page 2. It's really not that hard to 'wing it'. The Rod end is a 1/2 item.
    The shifter was completely constructed by me.
  16. legreg
    legreg New Member
    0Coins
    Ok sorry.
    One question, how did you fix the skate bearings on the delrin block? Thank you :)
  17. legreg
    legreg New Member
    0Coins
  18. Historiker
    9,212Coins
    Willynovi and Elnino, your designs and builds are excellent. Thank you both for sharing.
    I am currently planning SimPit MK2 and now plan on incorporating an H-shifter into it. This thread answered all my questions (thanks for posting the cad file Elnino) and hopefully I can get started on it within a month or so. I ordered all the parts that I need from Ebay this afternoon and they will be put to use when I finish my current project (a new steampunk brass and cherry case MK2 see MK1 here:http://www.overclock.net/case-mod-work-logs/468160-project-serenity-another-wooden-case.html#post5678563 ). The new pit will be a transformer, Mechwarrior pit, Flight Sim Pit and Racing pit. Thanks again for posting this info!
    David
  19. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    nice cut..do you have cnc machine or what
  20. Historiker
    9,212Coins
