Question Wobble up and down problem as soon as I plug in USB cables
Discussion in 'DIY Motion Simulator Projects' started by motiondynamics, Dec 17, 2022.
  1. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hi Gadget999, I didn't understand (I'm Italian and I use the translator).
    Can you explain it better?
    Thank you
    On this occasion, I wish you and all the enthusiasts a Happy New Year 2023.
  2. Gadget999
    12,132Coins
    A BLDC motornos normally 3 wires 120 degrees apart, there are 3 sets of magnetic fields.
    My guess is the BLDC driver is not being fed a new position and cant hold a stable position over time.
    Simtools and smc3 utils send regular updates on position. So the location is constantly updated.
    There are many ways to fix the problem using code, but you need to learn to program first !
  3. motiondynamics
    1,235Coins
    My brushless motor has 3 phases (H, V, W) and 3 Hall sensors.
    My drive has 3 phase outputs (H, V, W) and Hall inputs (H, V, W, 5v, gnd) and works with a maximum frequency of 1Khz.
    Your reasoning is correct, but then I don't understand one thing: during the oscillation, if I put a weight of 25Kg on the actuator, it stops oscillating. Because? If it was a problem you say, it should also swing when I put a 25Kg weight on it.
  4. Gadget999
    12,132Coins
    Try a smaller p number
  5. motiondynamics
    1,235Coins
  6. Gadget999
    12,132Coins
  7. motiondynamics
    1,235Coins
    I've already tried, I got less dynamics, oscillation always present.
    But I think it is useless to find the cause. I have already said that the ideal solution is to modify the code so that the motors are not active when the usb cable is inserted, ie: the motors should only be powered by the pwm when the game starts (as the xsim software does).
    Is it possible to modify SMC3 so that the engines only have power when starting the game?
  8. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    It could be that your potentiometers are damage or dirty at center position. While using smc3 utility if the wobble only happen at center position and gone at other position then it could be it. This could explain why when you start a game the wobble is gone. Because in some game the center position might be slightly different than smc3 default center position.
    Also when you put weight it will push the position down and away from center position.
  9. motiondynamics
    1,235Coins
    No, the potentiometers are new and clean.
    It would be appropriate that the code creator gives us concrete help every now and then, especially for us who have paid for a license.
  10. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    If changing Windows language to English fix your problem, but not convenient to you, maybe you can try just changing Windows decimal symbol from comma(,) to period(.)
    (If your country use comma as decimal point).
  11. motiondynamics
    1,235Coins
    I already tried to change the language to English, but it doesn't work.
    Comma (,) with period (.)?
    Meaning what? Explain better.
  12. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    Some country use comma as decimal point eg: 3452,12 instead of 3452.12
    This can be set in Windows
    But since changing language doesn't fix the issue then this may not be the problem.
    Your actuator is linear motion right? Like the d-box? Do you use sliding potentiometer or multi turn type that you attach directly to motor shaft?
  13. motiondynamics
    1,235Coins
    That's right, like d-box.
    I use linear potentiometers
  14. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    From this picture I see that your PWMmax is only 50. That will make the motor weak. Try to increase it to 250 and see what happen.
  15. motiondynamics
    1,235Coins
    Hi superwhitewish,
    I tried to change the PWMmax value by putting "200" but it doesn't change.
    I have something new: I noticed that even while driving (with rFactor, AI automatic driving), the engines go up and down (I noticed this with the HEAVE effect on straights).
    Could it be a BLDC drive problem?
  16. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    I did ask about your driver before because that was my first suspect.
    Some driver are for continuous running. They have slow acceleration and cannot change direction immediately.
    Run SMC3 and simulate square & triangle wave. If the motor keep overshoot during direction change than driver could be the problem.
  17. motiondynamics
    1,235Coins
    Hi, I carried out the test as you advised me, you can see the result.
    Tell me.
      175.9 KB
      255
      224.4 KB
      250
  18. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    Response looks sharp. That's good. But I notice the oscillation happens in certain area only. Lower area A it oscillates but upper area B it stays steady.
    Sorry but I don't have any more idea right now.
    Maybe you can check the potentiometer installation. make sure they don't get loose when the actuator moving or don't get forced side way.
    153,691Coins
    Given the evident poor tracking I consider kp and PWMmax likely need to be higher, with PWMrev also needing a value around that of PWMmax.
  20. motiondynamics
    1,235Coins
    Hello, the potentiometer is fixed, tightly locked.. The potentiometer is of very good quality (Bourne).
    I tried to increase both PWMmax and Kp, but the motors make an annoying noise (like frying).
