Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.2.0 Pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,236Coins
  2. Wagnard
    Wagnardsoft
    5,236Coins
    Update 14.01 pointers
  3. MoreSine
    MoreSine Member
    Hesse, Germany
    157Coins
    I can|t seem to get any Output from ED. I am still on Horizons, but on Update 14.01 -
    I tried Wagnards SimTools Plugin with the newest pointers and also the FlyPT Version someone posted here and updated to the newest pointers - no luck. I am running other programs fine with SimTools as well as with FlyPT Mover.
    Any Ideas that I could check? I do have ED installed on my D: drive, I will try moving it to C: but I doubt that this will help since at least FlyPT is detecting the executable correctly...
  4. Wagnard
    Wagnardsoft
    5,236Coins
    I'll give a look on my end, are you using horizons with 4.0 universe or the legacy on 3.8?
  5. MoreSine
    MoreSine Member
    Hesse, Germany
    157Coins
    Thanks! I’m using the 4.0 universe
  6. Wagnard
    Wagnardsoft
    5,236Coins
    It's working on my end. Some user got it working by right click / run as administrator on the gamemanager shortcut.
    You could also have an antivirus or security software that somehow prevent the memory hooking.
  7. MoreSine
    MoreSine Member
    Hesse, Germany
    157Coins
    thanks for your quick reply and testing.
    I tested running everything as admin (game engine, game manager, the ED executable) - doesn't help. The only security that was active was the windows firewall - disabled it - doesn't help.
    Moved the ED install directory to C: - doesn't help.
    Any tips on how I can debug this on my side?
  8. George Dobransky
    Hungary
    - 43Coins
    Hi There,
    Is the plugin still works at you guys? At me -since yesterday it is not working in ship and srv neither...
    Cheers,
    George
  9. Wagnard
    Wagnardsoft
    5,236Coins
    I'll check later, was there an update recently?
    Edit: Look like there was an update yesterday, I'll work on this soon
  10. George Dobransky
    Hungary
    - 43Coins
  11. Wagnard
    Wagnardsoft
    5,236Coins
    Update 14.02 pointers
  12. Wagnard
    Wagnardsoft
    5,236Coins
  13. George Dobransky
    Hungary
    - 43Coins
    BIG thx!!!
  14. Mechromancer
    434Coins
    Is the new plugin for SimTools v3? I'm getting the dreaded .NetFramework crash.
    Will it work on v2.6?
    Thanx
  15. Wagnard
    Wagnardsoft
    5,236Coins
    The plugin here is for SimTools 2.6
    Can you share the crash information?
  16. Historiker
    9,208Coins
    Can you make one for Simtools 3? Please sir? :thumbs
  17. Wagnard
    Wagnardsoft
    5,236Coins
    I already have, just check the Simtools 3 game plugin
  18. Historiker
    9,208Coins
    DoH! Thank you my friend!
  19. Mechromancer
    434Coins
    Thanx for your attention Wagnard.
    I was on 2.4. 2.5 was giving me wild behavior, even after doing a clean install.
    However, I installed 2.6 yesterday and it seemed to resolve the problem.
    Thanx again.
  20. TomSawyer2112
    TomSawyer2112 New Member
    Hobbies
    LU
    - 65Coins
    I cannot get any Elite plugin to create any motion on my rig with
    E.D. Horizons v 2023.01.26 291050 (or Odyssey 4.0.0 update 14.02)
    Everything looks like it should, I loaded the latest offsets, tried all others too,
    Simtools 2.6 works with other plugins like rFactor,
    your plugin activates, turns blue,
    connection is made with my rig 49hz,
    but no motion in the training section of the game.:(
