motor placing
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Ayad, Jan 4, 2023.
  1. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    hi , am asking about the using of 3 motors 2 in the as 120 degree and one in the front as mention by the french web page which offer the simkit of 3 motors ,is this work for simtools ,I mean do I need to change the code ?can I use this type of 3 motors together with IBT_2 ,because the page with simkit ,use the saberteeth driver ,I am so impresse3d with there building which seems smooth ,and its base ang the building by wood which might take off my problem with static or leak electricity and annoying shock ,
    AYAD
    153,697Coins
    Can you please clarify your intended design in a little more detail.
    A motor with lever becomes inefficient with more than 38-40 degrees up and down movement, so I am not sure what you mean by "2 in the as 120 degree and one in the front".
  3. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    I MEAN WHAT was published in simukit in french as in the pictures bellow
    upload_2023-1-5_23-40-49.png upload_2023-1-5_23-40-49.png upload_2023-1-5_23-42-4.png upload_2023-1-5_23-42-4.png upload_2023-1-5_23-40-49.png
  4. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    can use thissetting with simtool and ibt-2 driver .they offer kit with saberteeth driver
    153,697Coins
