Question Traction Loss motor & flight Yaw
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Nicki9knuckles, Jan 5, 2023.
  1. yobuddy
    50,750Coins
    What do your axis assignments look like buddy?
  2. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    @yobuddy i have heave rate assigned 100%
  3. yobuddy
    50,750Coins
    Let me give it a test tomorrow and see what I find.
  4. Nicki9knuckles
    Web Developer
    740Coins
  5. yobuddy
    50,750Coins
    Still working on the plugin, should have an update soon.
  6. Nicki9knuckles
    Web Developer
    740Coins
    That's awesome @yobuddy ! Thanks so much for looking into it. This software you have built is amazing!
  7. richdelta9
    8,860Coins
    I posted an updated plugin, so you can update and test to see if you are getting values as expected.
    I have a question for you. I see you are able to exit out of the game while it's running to capture values for max/min. I have not been able to do that. What are you doing to get out of the game without shutting it down? I have changed resolution and unchecked full screen, but don't see a windowed mode to escape out without needing to shut it down.
  8. Nicki9knuckles
    Web Developer
    740Coins
    Hey @richdelta9 , thank you SOoooo much! It's working now on Yaw Rate. When I assign my axis3a to Yaw Rate at 100% I am getting side to side movment now when using the twisting of my hotas flight stick! thats fantastic. Thanks so much
    Your question about switching apps without shutting down the game. I use Alt + Esc. Other games I can use Alt+tab but that doesn't work in this one for some reason. Also, not sure if this matters but in the settings->graphics. I have full screen unchecked
    Thanks a lot for all the help on this @richdelta9 @yobuddy
  9. richdelta9
    8,860Coins
    Good to hear it's working! Thanks for the Alt + Esc trick it worked! That has been driving me crazy lol.
  10. Nicki9knuckles
    Web Developer
    740Coins
    no problem @richdelta9 !
    Now for the long long process of learning how to fly in IL-2 haha
