  1. TyCrawford
    TyCrawford New Member
    - 149Coins
    Update; I swapped control wires from my #1 module over to my #2 module and it immediately started working in both directions. Still gonna build that test unit though just to make sure my #1 unit is bad, and see if any other units I have are bad. I feel like these cheap chinese units are bound to be a shot in the dark and so I'd rather know before installing them if they're good or not
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    If I remember well, those are the unit @SilentChill used to make is first simulator and he quit them as they had too many defects.
  3. TyCrawford
    - 149Coins
    Ill look into his posts to see what I can learn but at such a point the MonsterMoto shield isnt being made anymore and these cheap chinese h bridges suck, what units are folks using today?
    153,950Coins
    +11,159 / 57 / -2
    IB
    IBT2 and Cytron are popular, but there are other possibilities such as JRKs: https://www.xsimulator.net/community/faq/motor-drivers.11/category
  5. Gadget999
    12,156Coins
    a trick that may help you diagnose the problem is to fit leds on the pins for direction and pwm - you can test the chip is outputting this way ;)
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    I use sabertooth. But they are expensive. Beside melting my wires, I had no problem from my 3 units.
  7. TyCrawford
    - 149Coins
    Ok so I impulse bought some more of the BTS7960s when I first suspected mine was bad, so Im gonna run those til dead.
    I got both axes working snd moving yesterday! Super stoked. However getting a lot of noise on my feedback pot, especially in the uphill direction. That is to say. When the motor is just letting gravity take care of it, movement is very smooth and the feedback pot matches the desired position in SMC3Tool very well.
    Did some reading and found that if using mechanical pots, the way to go is 10k linear. Turns out Im using 50k linears. I might go to hall effect at some point but I can get 10k linears in stock in town today and will do so just to see if this is improved. Im also running non shielded cable to the pots and that might need replacement as well.
  8. Thomase123
    Thomase123 New Member
    - 41Coins
    I got also a problem
    The motor, when i connect the pot and try the "sine" in smc, it just spins and keep spinning.
    If i then take the pot in my hands og center it, if i turn it, the motor keeps spinning in that direction.
    Ive installed new pots, new ibt's - Nothing change.
    Im using the official picture for wiring and the code is changed to mode2.
    153,950Coins
    +11,159 / 57 / -2
    Can you please specify exactly what motors you are using and also post pictures of all of your settings.
  10. Thomase123
    - 41Coins
    Some 150w worm gear 12v motors
    The black and purple is going to the nr 3 pin
    153,950Coins
    +11,159 / 57 / -2
    You don't seem to have Max or Clip limits set.
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    Make sure your pot is wired correctly. I hade an issue with a pot that the variant pin was not in the center.
  13. Thomase123
    - 41Coins
    I know, but it does not change anything when i set it
  14. Thomase123
    - 41Coins
    Ohhh, that could be it. Let me try that
  15. Thomase123
    - 41Coins
    Is there a way i can check it?
  16. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    What pots are you using and how are they connected to the motor?
    153,950Coins
    +11,159 / 57 / -2
    You can move the pot by hand and the movement should show on the SMC3 graph.
  18. Thomase123
    - 41Coins
    I got a few 10k ohm, from diffrent brands. I got the + and - connected to the + and - from IBT and the to the UNO board 5v and gnd and then the signal to the first A on the UNO board
  19. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    You can check it with a multimeter, and check if the olms change as you turn the pot. It it doesn`t, you have found the two external pin. Then the other pin should be the center.
  20. Thomase123
    - 41Coins
    So, its alive, kinda
    Why does it look like this?
    The pots are attached and turning with the shaft now
