Question How to Vibe on Simtools v3
Discussion in 'SimTools Pro & Entertainment Version' started by Hermant Alexis, Jan 15, 2023.
  1. Hermant Alexis
    Hermant Alexis Member
    238Coins
    Hi
    Is there anybody that could help me on how to make my buttkicker work on simtools v3 pro?
    I have finished with the motion stuffs and my buttkicker previously worked as a classic woofer on my optical soundcard output (with a RCA convertor that input the amplifier).
    I don't find a tuto for v3 and don't know how to start to link my soundcard/optical output to the simtools v3 ...
    I have just one soundcard in my computer and one buttkicker in my setup.
    Thank you in advance!
  2. Hermant Alexis
    238Coins
    In the simtools v2 tuto, we can select the sound card here but I can't on v3 ...
    Do you think :
    1- I need another sound card to be available in the simtools ?
    2- If Yes, a simple "USB->Jack stereo soundcard" like we find a lot on amazon for 10€ is enough? (I have only one buttkicker).
    example:
  3. Hermant Alexis
    238Coins
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @Hermant Alexis
    Go to interface setup top right then look at the bottom left along there you will find vibe setup tab:thumbs
  5. Hermant Alexis
    238Coins
    Nice ! Thank you
  6. Adi800
    Adi800 New Member
    92Coins
    did You Managed it with the vibes??i have v3 and it doesnt Work
  7. yobuddy
    51,529Coins
    GameVibe in v3 is confirmed working buddy.
    Have you setup a sound card in the interface settings of v3?
    Take care,
  8. yobuddy
    51,529Coins
    Yep
    Pretty much any sound card that can do a 4 channel quadraphonic setup. (for best results)
    (I use a 5.1 card and turn the center and sub channel off.)
    We can do cheep 3d setups like this.
    Ebay 4 channel amp. $55 (last i checked)
    4 x Transducer pucks ~$19 (last i checked)
    Then mount 2 under (or by) the peddles. and 2 behind (or under) the seat.
    Anyway, chat soon!
  9. Adi800
    Adi800 New Member
    92Coins
    I can Setup IT and i can See my Soundcard and i can Test it and it works,but No Sound/Vibrations from game
  10. Adi800
    Adi800 New Member
    92Coins
    I have the Same Problem Like this Guy in YouTube in His Video. Type in in YouTube
    Simtools v3 Bass Shaker Problem.
  11. yobuddy
    51,529Coins
    Did you set any Hi/Low values for anything?
    See here I set up rpm to run between 100 and 9000 rpm
    Then I need to make sure it has volume.
    Let me know how it goes.
  12. yobuddy
    51,529Coins
  13. Adi800
    Adi800 New Member
    92Coins
  14. yobuddy
    51,529Coins
    Click Capture, set values and click Save, and then click Stop.
    Take care,
  15. Adi800
    Adi800 New Member
    92Coins
    Yeeees,thank You,that was ist.thxxxxxx
  16. Hermant Alexis
    238Coins
    On my side, it's all fine. Setup is finished with all ajustments I like.
    Finally I didn' need an external sound card. I use the internal for th VIBE and the output of my screen for my headphone.
    After some training, this simtools v3 is really great!
    Thank you all!
  17. Blame73
    Blame73 Well-Known Member
    8,314Coins
    Ok, I might be blind or stupid (or both) but I can't find anywhere the Vibe setup tab :confused:
    EDIT:
    OK, my problem was I had activated on v.3 the DIY licence and not the PRO.
    Solved (so, not blind but a bit stupid... :grin)
  18. Rico Mortis
    Rico Mortis New Member Gold Contributor
    84Coins
    hi guys
    trying to use a nobsound external sound card to work bassshakers but simtools v3 doesnt see the card
    any ideas??
    thanks in advance
  19. Hermant Alexis
    238Coins
    All I may say, it's not easy to manage that double sound output.
    In my case I only use one card (for the vibe), and the output of my screen (I suppose the sound comes through the HDMI).
    But last time I upgraded windows I couldn't get the two outputs working at the same time.
    After trying a lot of time and browsing all the setups of windows, I had to recover windows to the last recovery point... so it's OK but I don't touch anything anymore.
    Good luck!
  20. yobuddy
    51,529Coins
    Is the sound card listed in device manager and can you play music on it from windows?
