SimTools v3 Public Beta
  1. yobuddy
    51,524Coins
    SimTools v3 update posted! :thumbs
    Fixed - Auto Profiling from a name with illegal charters in the string.
    Fixed - Create unique file during patching error fixed
  2. ivan jack
    ivan jack Member
    412Coins
    I tried Dirt Rally with Roll force only activated on even terrain in free roam , but still has problems , when I enter the race the rig is tilting on one side then start violently move from side to side like Sway , but without Sway being activated. I noticed that Roll and Sway are both on same direction of travel , but in V2 works ok. Can this be the issue? Isn't Sway direction opposite to Roll? In test mode I need to set them like in the picture to give to right output. 20230124_094252 (1).jpg 20230124_094104.jpg
  3. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Im having a small issue with v3. When i lose motion in a sim, i try to reboot simtools v3. the problem is that it shows that it is still running as a process in task manager and i cant end task. The only way to clear it is to reboot the pc.
  4. yobuddy
    51,524Coins
    Try another usb cable and/or usb port to see what happens buddy.
  5. yobuddy
    51,524Coins
    @ivan jack,
    Rich is currently looking at dirt rally 2.
    Once I know what he finds I will get back to you buddy.
  6. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    I was having this issue on Simtools and SimRacingStudio. I was using a USB hub. The problem ceased once I moved the hub to a different port and used the DC power input for the hub.
  7. richdelta9
    8,850Coins
    I posted an updated Dirt Rally 2 plugin. this should provide good values for all outputs now. You want to have Sway opposite the other Sway and Roll opposite the other Roll. I attached what I was testing with on my 2DOF simulator. We are going to try and get all the plugins spitting out the data the same for each game so that global profiles should work with all plugins when we go back through them, but for now it is configurable.
  8. richdelta9
    8,850Coins
    I tested for this with the current V3 Dirt Rally and Dirt Rally 2 plugins and did not have any crazy sideways drifts before or during a race. It seamed to be working as expected for me. Are you still having this issue?
  9. ivan jack
    ivan jack Member
    412Coins
    I made another 2 videos to see difference from V2 which is working with no problems , but in V3 now with only roll activated the rig goes to one side at the start of the race on flat surface and start to shake . I had to stop it at the end of the video so nothing goes wrong. In the below pictures are my settings for both V2 and V3.
    V2 video
    V3 video
    https://youtube.com/shorts/EomSECZyy3Y
  10. yobuddy
    51,524Coins
    The pics are way to small buddy.
  11. ivan jack
    ivan jack Member
    412Coins
    edited
  12. yobuddy
    51,524Coins
    What is your max/min value for roll in v3?
  13. ivan jack
    ivan jack Member
    412Coins
  14. ivan jack
    ivan jack Member
    412Coins
    When trying to capture min/max settings "NaN" appears in both Roll and Roll rate fields.
  15. yobuddy
    51,524Coins
    Please remove the plugin and restart simtools.
    Then reinstall the plugin from the repo and see how it goes.
    Take care!
  16. ivan jack
    ivan jack Member
    412Coins
    working now! thank you !
  17. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    I tried today and
    I tried today and v3 is king for me again :) but I will wait until next gaming because for me v2 was like : "oh yea I got it" when I create profile but on next gaming was not the same motion profile. I don't know why. I write about rbr. Other games no problem. Today I create profile for v3 on rbr and FANTASCIC movement for me. I can set all 2 interfaces. No problem at all. So for now congrats but I'm wondering what will be next time. My settings :
  18. Tiago Dias
    Tiago Dias New Member
    89Coins
    Hello, I finally got it to work with the new software, I made these configs and I have some doubts, to capture max min can I always do the track I'm running or is it enough just on a track and use these settings for all? I also added antirollover to roll I read something out there that had to be used I don't know if I'm right or wrong. stay with the settings images
    153,728Coins
    When capturing a Max/Min it pays to use a mid-range track and car, then those results can be tweaked for other cars and tracks with specific profiles.
    Antirollover relates to what happens when the limits of the physical rig are exceeded by the game telemetry. For example, with traditional roll in a flight sim game the physical rig can't replicate the inversion of the transition to upside down, and will snap in an unrealistic manner to the opposite end of the axis movement range. Antirollover compensates for that in advance.
  20. Tiago Dias
    89Coins
    Thanks for the answer, so I'm wrong to use it, I did max/min in Mount Panorama because it's the next endurance I'm going to have, being my motion 2dof seat motion I didn't like the pitch very much, especially in mount panorama I had to use very low values, maybe these settings are enough for what I have, however I'm playing around with the settings to find out and learn more about it
