SimTools v3 Public Beta
  1. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Pitch is not included in the settings you posted, but even for those that are, the total % allocation is likely approaching being too high: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    What I am suggesting is that further motion profile refinement is likely needed.
    Personally there are aspects of Mount Panorama's elevation changes that should be reflected in a motion profile, given how drastic they are IRL.
  2. coyote1168
    coyote1168 New Member Gold Contributor
    - 53Coins
    Hi, I'm starting to test Simtools v3 and it's great!... I noticed on the axis limiting page, if I reduce for example the limit to 25% on an axis and I click on the cross to reset to 100%, then it is always 25% that is returned in the gameor in test setting.I have to use the slider to reset 100%.. So I think there is a reset problem with the cross button
  3. coyote1168
    - 53Coins
    it would be great if it was possible to limit with different positive and negative values.
    For the surge, by using the max for the negative limit and 0 for the positive limit, we would only take into account braking and not acceleration, which could be used for belt tensioners for example
    It would really be a change compared to version 2
  4. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    @yobuddy does this beta not need us uni code?
  5. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Just tested dirt rally 2 on v3 and I can confirm it works fantastic. One happy chap! Thanks so much for all your work on it.
  6. yobuddy
    51,553Coins
    If you mean needing to set any kind of local region settings, then nope.
    That v2 problem is fixed in v3.
    Take care,
  7. yobuddy
    51,553Coins
    It already works like this buddy.
    We can simply use a zero for one side to turn it off.
    There is also output types options in the advanced axis plugin that's meant for g-seats.
    Take care!
  8. flipflop
    Swansea
    382Coins
    3DOF, Arduino
    Up till now I have only used the basic axis plugin on simtools 3. Am I able to just download the standard plugin? Will it affect the existing setup or do I need to delete the basic axis plugin first?
  9. yobuddy
    51,553Coins
    Yes, you can install the standard and advanced plugin also with no problem. :thumbs
  10. ivan jack
    ivan jack Member
    412Coins
    Tested WRC Generations and found out same conflict between Sway and Roll being on same direction of travel. Tested separately working ok , but when applied together rig goes crazy from side to side.
  11. coyote1168
    - 53Coins
    Yes!.. I find how to do ;)
    With the "set #2" in Min/Max Tuning, we can use a specific conf for a axis belt and use "set #1" for the 2dof seat
    I don't find this possibility with the simtools v2
  12. yobuddy
    51,553Coins
    The direction of a DOF output is 100% configurable in the axis assignments.
    Simply click the Direction (Dir) button to flip the output buddy.
  13. yobuddy
    51,553Coins
    You have to goto options and set the mode to expert.
    Take care!
  14. ivan jack
    ivan jack Member
    412Coins
    I know that. The problem is ,only way to tilt on the correct side in game is if you put those on same direction of travel. (See pic) If you drive slowly works but when bigger forces are applied rig starts to go from side to side. I had same problem with Dirt Rally but that was fixed few days ago. In test mode everything works , but in game is a conflict between sway and roll. I hope I explained it right. In the picture roll should be opposite to sway. But if I put it like that in game the rig goes to opposite direction than it should. If the problem is not clear I will make a more detailed video
  15. yobuddy
    51,553Coins
    It makes no difference weather we flip the output in the plugin itself thou, or the first step in the axis plugin, Ultimately its the same output.
    Take care,
  16. flipflop
    Swansea
    382Coins
    3DOF, Arduino
    Just wanted to report a slight issue with simtools v3 when using assetto corsa. If you exit a practice race, before you are returned to the menu screen, simtools screen appears for a second then dissappear. If you now return to the race, all your movement in the rig is lost. You have to exit the game, then restart for motion to resume.
  17. coyote1168
    - 53Coins
    Great! I didn't know about this option. Thank you very much for this tip!.. I discover new possibilities ;)
  18. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello... A simple request: during the RaceRoom plugin installation phase what should be the right path to indicate so that the operation can be successful? I'm trying but I always get an incorrect path error :confused:
  19. early_m
    early_m Active Member
    Chelmsford
    839Coins
    No such issue here, are you using the native menu or content manager?
  20. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Hey guys. Just doing some testing in Richard Burns Rally. The surge seems to be throwing some funny values. while im braking or accelerating its kinda jumping all over ther place. Is anyone else experiencing this?
