FlyPT Mover 3.5.3
  1. Historiker
    9,214Coins
  2. Grucho
    Grucho Member
    232Coins
    Hello. I could not get it working with the 2x25A v2 sabertooth. I ordered the 2x60. As soon as they will arrive i will let you know.
  3. pmvcda
    15,660Coins
    I think it should work...
  4. pmvcda
    15,660Coins
    Looking at it
  5. pmvcda
    15,660Coins
    Please take a look at the site, but LFS as a new version with more data, and the latest version of Mover is made for that version.
    If you are using an old LFS it might not work.
  6. Grucho
    Grucho Member
    232Coins
    Probably, but i had to modify then the code for arduino to find the correct baud rate and since it was starting to create problem i decided to return the 2x25 and go for the 2x60 better model. At least i will be aligned with all the guides and posts on the forums and not introduce other errors.
    One question, meanwhile i get the new motordrives, i was trying to figure out how to use flypt to drive 3 motors that spins omniwheels and control a sphere on top of them. Looking around looks pretty complicated.
    My plan is to use 3 arduinos, 2 for the motors outside the sphere, one inside the sphere that sends orientation data outside to the motors so they can keep track of the orientation of the sphere, the slip factor and so.
    How can i use flypt to drive such a system and also to make the correct calculations for making the 3 motors working together to find the desired position/motion? Is it possible? Here i found a paper that describes basically what I am tryibgto achieve in theory, but from theory to practical there is a huge gap. You can see the pdf attached.
    Thanks!
  7. Roller2525
    Roller2525 Member
    220Coins
    Hey @pmvcda
    I requested this some time ago and you said that it was possible..
    Do you think a weapon release (bombs) effect could be included in the next release?
  8. Roller2525
    Roller2525 Member
    220Coins
    My old post for reference..
  9. Roller2525
    Roller2525 Member
    220Coins
  10. pmvcda
    15,660Coins
    For this to work, you should send to the arduino with the sensor, what is the desired orientation (yaw, roll and pitch).
    In that arduino, having both the desired orientation and the sensor orientation, your math decides how to move the motors to achieve the desired orientation.
    It's how it works with linear actuators, you send them the desired position and the controller acts depending on the current position.
    This is why I said you should use the rig just pose.
    Not sure the Arduino is fast enough for the math.
  11. pmvcda
    15,660Coins
    ... I think I have it already, I have to see, might be confusing with other sims.
    Added to the list to verify
  12. Roller2525
    Roller2525 Member
    220Coins
    Thanks!
  13. Grucho
    Grucho Member
    232Coins
    Ok. Theory seems clear to me now. As soon i will get the hardware i will try to connect the prototype and let you know. Many thanks for the help
  14. Michail
    748Coins
    Is there a discord server for flypt mover?
  15. Racerr87
    Racerr87 New Member
    6Coins
    There is a flypt mover section in the thanos motion discord.
  16. Bjarte Myklebust
    Bjarte Myklebust New Member
    48Coins
    I Finally found out that it was not simtools causing microstutter in ACC. As Simtools was only the last drop to make it very noticeable. The main issue was that "in game steam overlay" was enabled.
    /Bjarte
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    I tried to connect mover with the new Simtools 3. Every times I tried, Simtools simply crashed. I guess it is not compatible. It still works well with Simtools 2.6. Am I the only one having tried it with Simtools 3?
  18. Michail
    748Coins
    Where can I find the parameter for maximum rotate angle of the motor? Pose limits are red and shown out of range.
  19. Michail
    748Coins
    Hello Guys, I hope you can help me to solve my problems. I add a rig H3 because it is similar to mine DIY, 2dof and traction loss.
    Where can I set the axes limits? like in simtools? What ist the different between pose limits and drive pose? and how to setup when i want to add 50° up and 50° down?
    How can I invert, when motor one on dirve positive run right, and motor 2 positive drive left? Where can I setup which axes is which motor?
    I want to use "car blackbox" ore "form motion" or only for virtual tracker and stay with simtools for motion. But honestly I would like the motion to get from flypt, because i like the RPM and suspension motion so much.
    What to setup here:
    I will add an extra motor back to have at the back 2 motors combined to have traction loss and combined with the 2 on the front ability for heave. How to setup this then as rig? Do I have to choose '"just pose output" or 4 x "1 DOF with single rotating actuator"?!
    Maybe there is an dedicated flyptmover discord except of the thanos discord?
  20. wingert
    wingert Active Member
    684Coins
    4DOF
    afaik, pose limit is the max travel or rotation like a software limiter. Start position is normally from zero to a middle position (127 000) while drive position is variation from that middle point like a offset or shift.
    The software calculates the position change, the motor direction left or right is managed from the motor controller.
