Windscreen motors higher voltage
Discussion in 'Motor actuators and drivers' started by Mattlekim, Feb 4, 2023.
  1. Mattlekim
    Mattlekim Member
    - 5Coins
    I have 2 windscreen motors. As far as I know they are 12v.
    Would putting 24v through blow them, or just shorten there life?
    I'm not sure as I know more voltage would be increased speed and increased speed would be the main problem with damage. But in a motion simulator they are not running at full speed sustained.
    Also I know that higher voltage generally means you need thiner wire, but I don't know how this would effect the motor coil?
    Thanks matt
  2. Arta Yasa
    Arta Yasa Member
    968Coins
    I think it will burn the motor coil, i think motor wiper 12v strong use only for the seat not all rig, because i try all rig the wiper very fast hot, its my experience
  3. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    You will spoil the engine, if you want more speed you will have to look for another alternative
    153,788Coins
    +11,150 / 57 / -2
    You can under volt a DC motor, but over volting will result in damage.
  5. Mattlekim
    Mattlekim Member
    - 5Coins
    Thanks for the feedback. Appreciate it.
  6. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Doubling the voltage results in four times the power through the motor. I would expect the motor to blow almost immediately. Motors have some safety margin, especially since in an automotive application the voltage often runs 13-14 volts instead of 12v. A windshield wiper motor is likely okay up to about 15v for a short period, but I'm not sure the exact specs.
  7. Allwin Joseph
    Allwin Joseph ajstan
    Student
    Bengaluru,India
    12Coins
    You can rewind the motor to handle 24v , but that is a tedious process, you can opt for wiper motors from trucks those are designed to handle 24v, those are also a lot torquier , you can get it for dirt cheap!!!!
  8. zapata_h
    España
    308Coins
    Rewinding the motor I don't think is the best solution, using truck motors is a good idea
