2DOF 3phase motors
Discussion in 'DIY Motion Simulator Projects' started by Valentin1985, Feb 5, 2023.
  1. Valentin1985
    Valentin1985 New Member
    - 60Coins
    2DOF, AC motor
    Hello everyone
    I am building a motion platform on three phase motors.
    Controlled by SMC3
    The platform is almost built. There are some minor management issues. I want to use a platform with glasses. But when the Oculus quest 2 motors are running, it issues a communication error with the computer
  2. Gadget999
    12,035Coins
    What type of motor controller do you use ?
  3. Valentin1985
    - 60Coins
    2DOF, AC motor
    Arduino uno and homemade shield pwm-analog. Lm358
  4. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Three-phase motors with vdf generate a lot of electrical noise
  5. Gadget999
    12,035Coins
    Do you provide a 0-10v signal to the vfd ?
  6. Valentin1985
    - 60Coins
    2DOF, AC motor
    This frequency converter uses a 5 volt analog input. On the board, I did not provide an opto-link to the operational amplifier. I'll redo the board soon.
    The oscilloscope shows small fluctuations on the 5 volt line. I tried to install capacitors on the power supply.It got better but the problem remained
    152,523Coins
    +11,085 / 56 / -2
    What exactly is the communication error, is it a USB disconnect or something else?
  8. Valentin1985
    - 60Coins
    2DOF, AC motor
    I tested on the epic roller coaster. The game starts. When the motors start moving, an error occurs - the connection to the computer is interrupted. This connection can be resumed and the game will continue. After a few seconds, the error repeats. The glasses are connected via a link usb 3.0 cable
    152,523Coins
    +11,085 / 56 / -2
    Please post a picture of the full error.
  10. Valentin1985
    - 60Coins
    2DOF, AC motor
    The error appears in the glasses - the computer is not connected. I can't take a screenshot
  11. zapata_h
    España
    308Coins
    And it only appears when the engines are running? There must be some conflict with the USB, you can try running simtools on 2 PCs to avoid usb problems
    152,523Coins
    +11,085 / 56 / -2
    Try disconnecting the HMD, does the error still occur and if so please post a screenshot.
    If it is a USB disconnect, then see the FAQs here, as HMDs can use a lot of USB bandwidth, and computers often share controllers between external ports: https://www.xsimulator.net/community/reports/785/
  13. Valentin1985
    - 60Coins
    2DOF, AC motor
    The problem is most likely interference. I redid the board, added an optocoupler to pwm - analog. It did not help. I can attach oscillograms if necessary, but when the motors are running. Interference can reach one volt. Now I plan to put the frequency converters in an iron box. I tried to isolate the control board, which did not bring the desired result.
    Please look at the delay in work. This is fine? Who faced? I looked through the entire forum, but there is little information on the vfd motor
  14. zapata_h
    España
    308Coins
    We assume that motors and drives are grounded
  15. Valentin1985
    - 60Coins
    2DOF, AC motor
    Of course they were grounded. I needed to additionally shield the signal wires. After changing the box and shielding, everything worked perfectly. There is no interference at five volts. Glasses no longer fall off. Thanks to all who responded.
  16. zapata_h
    España
    308Coins
    I'm glad it's working properly
