2dof rig. (Hopefully very cheap)
Discussion in 'DIY Motion Simulator Projects' started by Mattlekim, Jan 30, 2023.
  1. Mattlekim
    Mattlekim Member
    - 5Coins
    Hello everyone starting to build my first motion platform this week. Can't wait. My supplies should be here tomorrow .
    My plan is to build one on a small budget. £240 without a rig. £380 with building a full aluminium rig.
    Will post regular updates and hopefully a tutorial and guild on how I did it.
    Thanks for the awesome forum and resources
    Matt
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    We look forward to your progress, good luck
  3. Mattlekim
    Mattlekim Member
    - 5Coins
    First parts have arrived. I'll have other motor tomorrow and 10 gauge wire.
    Going to install software and do a basic test soon before I assemble it all.
  4. zapata_h
    España
    308Coins
    It is always good to make a first contact with the electronics and if everything works, build the platform.
  5. zapata_h
    España
    308Coins
    Remember to completely isolate the mass of the motors
  6. Mattlekim
    Mattlekim Member
    - 5Coins
    So got myself a prototype board
    And soldered 2 strips of wire on the back so that I can have a positive and ground rail.
    Then iv started wiring up the wires I will need to the front.
    My plan is to leave space in the center for the arduino board and install it on top of the prototype board the. I can wire it up.
    Cost so far
    £52 becuase I already had some old parts lying around.
    Without them it would be £92
  7. zapata_h
    España
    308Coins
    You can put arduino in the center connected female pins so that you can remove arduino without desoldering anything from the circuit
  8. Mattlekim
    Mattlekim Member
    - 5Coins
    So got my first motor connected to the potentiometer via a pulley. Seams to work well.
  9. Mattlekim
    Mattlekim Member
    - 5Coins
    Actually got the test working and motors running
    However the pulley idea not so good. There is way to much sponge and that causes an oscillation. Was going to upload a video but blew the only fuse I had
    I have a solution that should work which I will test when I get my fuses
  10. Mattlekim
    Mattlekim Member
    - 5Coins
    Got a new mounting solution
    Plan to have a friend 3d print a bespoke part but do far so good.
  11. Mattlekim
    Mattlekim Member
    - 5Coins
    First problem. Like an fool if accidentally flipped the polarity to the h bridge!
    Boom! Blew capacitor, scared the living daylights out of me lol
  12. Mattlekim
    Mattlekim Member
    - 5Coins
    So tested both motors all working good.
    Mounted them to the base.
    Now I have broken 4 potentiometers though. They seem to fail stupidly easily!
    Do hall effect sensor fail as easy or are they more reliable?
    I plan to upgrade to them in the future just when for potentiometers as I come to grip with the rig
  13. noorbeast
    150,037Coins
    +10,993 / 54 / -2
    Hall sensors are more robust and won't break if over rotated.
    But what causes the damage? Are the pots being mechanically being driven past their limit or is it an electrical issue, as the latter would need to be resolved regardless of what you use.
  14. Mattlekim
    Mattlekim Member
    - 5Coins
    3 failed after soldering. Must have been to much heat, even though I was careful.
    They can't over rotate as it's not physically possible.
    The latest failure must be due to movement installing the mount in the rig.
    But still that's 4? Ether that or they are just crap ones.
    150,037Coins
    +10,993 / 54 / -2
    Too much heat could be an issue.
  16. Radje748
    Radje748 Member
    239Coins
    Yep, looks like too much heat...
    These things are internally somewhat vulnerable.... So How I do it, first some solder on all parts....make a bit warm...and than put them together, where it only needs 1 sec to connect properly
    And also check if you did not drop some solder between one of the 3 legs.... can also create a short circuit
  17. zapata_h
    España
    308Coins
    The correct thing is to have the soldering iron preheated, add a little tin to the pins of the potentiometer, tin is applied to the cables and then they are soldered to the potentiometer, this last step is very fast and the potentiometer should not be damaged internally
  18. Mattlekim
    Mattlekim Member
    - 5Coins
    Yea I got a new tip for my iron, as my old one was warm and heating unevenly.
    New tip is way better and gets hot in under 10 seconds
    I'll move over to hall effects when I have the build working
  19. zapata_h
    España
    308Coins
    The hall sensor is much more durable
  20. Mattlekim
    Mattlekim Member
    - 5Coins
    Progress .
    Also tinkered with some coding to better understand the board. Made a motor controller to run on with a button press accelerate up to speed etc and have an emergency stop button.
    Next up attached to the rig
