Question IBT-2 lock up
Discussion in 'Motor actuators and drivers' started by miaziol, Feb 20, 2022.
  1. miaziol
    miaziol Member
    Poland
    - 74Coins
    I have a strange problem. Specifically with one ibt-2 if I set the pwm above 10Hz it locks up, only cutting off the power helps. I put a gear ratio of 60: 1 instead of 40: 1, it didn't change anything. Even if I put a new driver there, the same thing happens.
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Attach an image of your configuration
  3. Allwin Joseph
    Allwin Joseph ajstan
    Student
    Bengaluru,India
    12Coins
    if it doesnt fix it even after changing the driver, you will have to check everything from your AVR board to the potentiometer, attach an image of ur setup.
  4. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Hello, I bought IBT2 drivers, assembled the drive and it did not work correctly, but worked jerkily. Then I removed the potentiometer and checked it with a tester, it turned out that it did not change its resistance linearly. I had to replace it.
