Question Whats wrong with my setting SMC3
Discussion in 'Ready, set, go - Start your engines' started by Arta Yasa, Feb 8, 2023.
  1. Arta Yasa
    Arta Yasa Member
    968Coins
    Hi i set smc 3 like this.
    And my set up like this.
    And i run sine or everything on smc3 utility, but when i hold the motion the motor will off, like the motor not have full power.
    And smc 3 is like this.
    I used pararel of bts, and 24v 13A PSU.
    Mybe somebody can help me. Thank you
    153,824Coins
    +11,151 / 57 / -2
    Kp seems to me a bit high, as does PWMmax and PWMrev, while Max Limits and Clip Input seem pretty low, with a bunch of other settings seemingly questionable, given those parameters.
    Much and all that I appreciate it is a pain, may I suggest starting from scratch, following the SMC3 setup steps exactly, so there is a known base for the likes of PWMmax (when movement starts), then members may be able to make further recommendations working from that known base:
    8. Set Kp to about 400
  3. Arta Yasa
    Arta Yasa Member
    968Coins
    I will try again sir,
  4. Allwin Joseph
    Allwin Joseph ajstan
    Student
    Bengaluru,India
    12Coins
    did you check your potentiometer? the green line is the feedback, and it doesnt look how it should look, try swapping the motor polarity.
  5. Arta Yasa
    Arta Yasa Member
    968Coins
    I think its correct the feedback going to targer, but i think because my motor is 300rpm, so too fast and low torque, for now i buy the gearbox for get rpm around 60 until 80rpm.
